Datasheet Texas Instruments TAS5706BPAPR — Даташит
Серия | TAS5706B |
Модель | TAS5706BPAPR |
Усилитель мощности звука I2S с замкнутым контуром, 20 Вт, эквалайзером динамика, DRC и поддержкой выходов SE 64-HTQFP от 0 до 85
20W stereo Digital Audio Power Amplifier With EQ and DRC. datasheet
PDF, 1.9 Мб, Версия: D, Файл опубликован: 10 сен 2009
Купить TAS5706BPAPR на РадиоЛоцман.Цены — от 89 до 660 ₽ 15 предложений от 12 поставщиков Audio Amp Headphone/Speaker 1-CH Mono/2-CH Stereo/4-CH Stereo 20.6W Class-D 64-Pin HTQFP EP T/R | |||
TAS5706BPAPR Texas Instruments | от 89 ₽ | ||
TAS5706BPAPR Texas Instruments | 252 ₽ | ||
TAS5706BPAPR Texas Instruments | 431 ₽ | ||
TAS5706BPAPR Texas Instruments | по запросу |
Pin | 64 |
Package Type | PAP |
Industry STD Term | HTQFP |
JEDEC Code | S-PQFP-G |
Package QTY | 1000 |
Carrier | LARGE T&R |
Маркировка | TAS5706B |
Width (мм) | 10 |
Length (мм) | 10 |
Thickness (мм) | 1 |
Pitch (мм) | .5 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Analog Supply (V) | 3 Max |
Audio Input Type | Digital |
Closed/Open Loop | Closed |
Control Interface | Hardware,Software |
Рабочий диапазон температур | от 0 до 85 C |
Package Group | HTQFP |
Package Size: mm2:W x L | 64HTQFP: 144 mm2: 12 x 12(HTQFP) PKG |
Power Stage Supply(Max) | 26 В |
Power Stage Supply(Min) | 10 В |
Power to Bridge Tied Load(Max) | 20 W |
Rating | Catalog |
Sampling Rate(Max) | 192 kHz |
Sampling Rate(Min) | 32 kHz |
Speaker Channels | 4 Max |
Supported Bridge Tied Load(Min) | 8 Ohms |
- Evaluation Modules & Boards: TAS5706EVM2
TAS5706B Evaluation Module (EVM)
- TAS57xx Dynamic Range ControlPDF, 324 Кб, Файл опубликован: 18 июн 2010
This application report provides background information, general equations, and instructions for proper use of the Texas Instruments TAS57xx series Dynamic Range Control (DRC). Topics include I2C configuration, single-band and dual-band DRC, coefficient computation, device offerings, and user interface configuration. - AN-1737 Managing EMI in Class D Audio Applications (Rev. A)PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit. - AN-1849 An Audio Amplifier Power Supply Design (Rev. B)PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs. - Guidelines for Measuring Audio Power Amplifier PerformancePDF, 765 Кб, Файл опубликован: 30 окт 2001
This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TAS5706B (2)
- TAS5706BPAP TAS5706BPAPR
- Semiconductors > Audio > Mid-Power Audio Amplifiers (10-50W) > Digital I2S Input Class-D
