Datasheet Texas Instruments SN74LVC125AQDRQ1 — Даташит
Серия | SN74LVC125A-Q1 |
Модель | SN74LVC125AQDRQ1 |
Автомобильный каталог Четверной буферный вентиль шины с выходами с 3 состояниями, 14-SOIC -40–125
Quadruple Bus Buffer Gate With 3-State Outputs datasheet
PDF, 796 Кб, Версия: B, Файл опубликован: 9 апр 2008
Купить SN74LVC125AQDRQ1 на РадиоЛоцман.Цены — от 13 до 40 ₽ 18 предложений от 11 поставщиков Automotive Catalog Quadruple Bus Buffer Gate With 3-State Outputs 14-SOIC -40 to 125 | |||
SN74LVC125AQDRQ1 Texas Instruments | от 13 ₽ | ||
SN74LVC125AQDRQ1 Texas Instruments | 13 ₽ | ||
SN74LVC125AQDRQ1 Texas Instruments | 16 ₽ | ||
SN74LVC125AQDRQ1 Texas Instruments | 34 ₽ |
Pin | 14 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | LC125AQ |
Width (мм) | 3.91 |
Length (мм) | 8.65 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Bits | 4 |
F @ Nom Voltage(Max) | 100 Mhz |
ICC @ Nom Voltage(Max) | 0.02 мА |
Output Drive (IOL/IOH)(Max) | -24/24 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 14SOIC: 52 mm2: 6 x 8.65(SOIC) PKG |
Rating | Automotive |
Schmitt Trigger | No |
Technology Family | LVC |
VCC(Max) | 3.6 В |
VCC(Min) | 1.65 В |
Voltage(Nom) | 1.8,2.5,2.7,3.3 В |
tpd @ Nom Voltage(Max) | 5.3,4.6 нс |
- LVC Characterization InformationPDF, 114 Кб, Файл опубликован: 1 дек 1996
This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices. - Use of the CMOS Unbuffered Inverter in Oscillator CircuitsPDF, 796 Кб, Файл опубликован: 6 ноя 2003
CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC125A-Q1 (3)
- CLVC125AQPWRG4Q1 SN74LVC125AQDRQ1 SN74LVC125AQPWRQ1
- Semiconductors > Logic > Buffer/Driver/Transceiver > Non-Inverting Buffer/Driver
