Datasheet Texas Instruments SN74LVC16T245DGVR — Даташит
Серия | SN74LVC16T245 |
Модель | SN74LVC16T245DGVR |
16-битный приемопередатчик с двойной шиной питания и настраиваемым сдвигом уровня/преобразованием напряжения 48-TVSOP от -40 до 85
SN74LVC16T245 16-bit Dual-Supply Bus Transceiver With Configurable Level-Shifting / Voltage Translation and Tri-State Outputs datasheet
PDF, 1.2 Мб, Версия: B, Файл опубликован: 28 апр 2015
Купить SN74LVC16T245DGVR на РадиоЛоцман.Цены — от 54 до 2 009 ₽ 36 предложений от 16 поставщиков TEXAS INSTRUMENTS SN74LVC16T245DGVR Transceiver, Translating, LVC Family, 16Input, 32mA, 4.2ns, 1.65V to 5.5V, TVSOP-48 | |||
SN74LVC16T245DGVR Texas Instruments | 54 ₽ | ||
SN74LVC16T245DGVR Texas Instruments | 67 ₽ | ||
SN74LVC16T245DGVR Texas Instruments | 248 ₽ | ||
SN74LVC16T245DGVR Texas Instruments | 1 868 ₽ |
Pin | 48 |
Package Type | DGV |
Industry STD Term | TVSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | LDT245 |
Width (мм) | 4.4 |
Length (мм) | 9.7 |
Thickness (мм) | 1.05 |
Pitch (мм) | .4 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
- LVC Characterization InformationPDF, 114 Кб, Файл опубликован: 1 дек 1996
This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices. - Use of the CMOS Unbuffered Inverter in Oscillator CircuitsPDF, 796 Кб, Файл опубликован: 6 ноя 2003
CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC16T245 (11)
- Semiconductors > Logic > Voltage Level Translation > Direction Controlled Voltage Translation
