Datasheet Texas Instruments 8413401EA — Даташит
Серия | SN54ALS153 |
Модель | 8413401EA |
Двойные селекторы/мультиплексоры данных 1 из 4 16-CDIP от -55 до 125
Dual 1-of-4 Data Selectors/Multiplexers datasheet
PDF, 762 Кб, Версия: A, Файл опубликован: 1 дек 1994
Купить 8413401EA на РадиоЛоцман.Цены — от 877 до 897 ₽ 8 предложений от 8 поставщиков DUAL 1-OF-4 DATA SELECTORS/MULTI | |||
8413401EA Texas Instruments | 877 ₽ | ||
8413401EA Texas Instruments | по запросу | ||
Pin | 16 | 16 |
Package Type | J | J |
Industry STD Term | CDIP | CDIP |
JEDEC Code | R-GDIP-T | R-GDIP-T |
Package QTY | 1 | 1 |
Carrier | TUBE | TUBE |
Маркировка | 8413401EA | SNJ54ALS153J |
Width (мм) | 6.92 | 6.92 |
Length (мм) | 19.56 | 19.56 |
Thickness (мм) | 4.57 | 4.57 |
Pitch (мм) | 2.54 | 2.54 |
Max Height (мм) | 5.08 | 5.08 |
Количество каналов | 2 |
F @ Nom Voltage(Max) | 75 Mhz |
ICC @ Nom Voltage(Max) | 14 мА |
Package Group | CDIP |
Package Size: mm2:W x L | See datasheet (CDIP) PKG |
Rating | Military |
Schmitt Trigger | No |
Technology Family | ALS |
VCC(Max) | 5.5 В |
VCC(Min) | 4.5 В |
Voltage(Nom) | 5 В |
tpd @ Nom Voltage(Max) | 21 нс |
RoHS | See ti.com |
- Bus-Interface Devices With Output-Damping Resistors Or Reduced-Drive Outputs (Rev. A)PDF, 105 Кб, Версия: A, Файл опубликован: 1 авг 1997
The spectrum of bus-interface devices with damping resistors or balanced/light output drive currently offered by various logic vendors is confusing at best. Inconsistencies in naming conventions and methods used for implementation make it difficult to identify the best solution for a given application. This report attempts to clarify the issue by looking at several vendors? approaches and discussi - Advanced Schottky (ALS and AS) Logic FamiliesPDF, 1.9 Мб, Файл опубликован: 1 авг 1995
This document introduces the advanced Schottky family of clamped TTL integrated circuits (ICs). Detailed electrical characteristics of the 'AS and 'ALS devices with table formats are provided. Guidelines for designing high-performance digital systems using the Advanced Schottky family are given along with a brief summary of the solutions to most design decisions needed to implement systems using t - Input and Output Characteristics of Digital Integrated CircuitsPDF, 1.7 Мб, Файл опубликован: 1 окт 1996
This report contains a comprehensive collection of the input and output characteristic curves of typical integrated circuits from various logic families. These curves go beyond the information given in data sheets by providing additional details regarding the characteristics of the components. This knowledge is particularly useful when for example a decision must be made as to which circuit shou - Designing With Logic (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 1 июн 1997
Серия: SN54ALS153 (5)
- 8413401EA 8413401FA SN54ALS153J SNJ54ALS153J SNJ54ALS153W
- Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Decoders/Encoders/Multiplexers
