Datasheet Texas Instruments OPA2835TDA2 — Даташит
Серия | OPA2835-DIE |
Модель | OPA2835TDA2 |
OPA2835-DIE ULTRA LOW-POWER, RAIL-TO-RAIL OUT, NEGATIVE RAIL IN, VFB OP AMP datasheet
PDF, 100 Кб, Файл опубликован: 30 янв 2013
Купить OPA2835TDA2 на РадиоЛоцман.Цены — от 1 082 до 10 621 ₽ 11 предложений от 8 поставщиков Voltage Feedback Amplifier 2 Circuit Rail-to-Rail Die | |||
OPA2835TDA2 Texas Instruments | 1 082 ₽ | ||
OPA2835TDA2 Texas Instruments | 2 023 ₽ | ||
OPA2835TDA2 Texas Instruments | 2 026 ₽ | ||
OPA2835TDA2 Texas Instruments | 2 179 ₽ |
Package Type | TD |
Package QTY | 10 |
Carrier | TUBE |
RoHS | See ti.com |
- Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA2835-DIE (2)
- OPA2835TDA1 OPA2835TDA2
- Semiconductors > Space & High Reliability > Amplifier > Operational Amplifiers
