Datasheet Texas Instruments OPA358AIDCKTG4 — Даташит
Серия | OPA358 |
Модель | OPA358AIDCKTG4 |
Высокоскоростной операционный усилитель с однополярным питанием 3 В, 80 МГц в SC70 6-SC70 от -40 до 85
3V Single-Supply 80MHz High-Speed Op Amp in SC70 datasheet
PDF, 844 Кб, Версия: C, Файл опубликован: 3 фев 2005
Купить OPA358AIDCKTG4 на РадиоЛоцман.Цены — от 45 до 336 ₽ 12 предложений от 9 поставщиков 3V Single Supply 80MHz High-Speed Op Amp in SC70 6-SC70 -40℃ to 85℃ | |||
OPA358AIDCKTG4 Texas Instruments | 45 ₽ | ||
OPA358AIDCKTG4 Texas Instruments | 57 ₽ | ||
OPA358AIDCKTG4 Texas Instruments | 87 ₽ | ||
OPA358AIDCKTG4 Texas Instruments | 93 ₽ |
Pin | 6 |
Package Type | DCK |
Industry STD Term | SOT-SC70 |
JEDEC Code | R-PDSO-G |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | AUS |
Width (мм) | 1.25 |
Length (мм) | 2 |
Thickness (мм) | .9 |
Pitch (мм) | .65 |
Max Height (мм) | 1.1 |
Mechanical Data | Скачать |
2nd Harmonic | 75 dBc |
3rd Harmonic | 83 dBc |
@ MHz | 1 |
Acl, min spec gain | 1 V/V |
Additional Features | Shutdown |
Архитектура | CMOS,Voltage FB |
BW @ Acl | 80 МГц |
CMRR(Min) | 60 дБ |
CMRR(Typ) | 80 дБ |
GBW(Typ) | 80 МГц |
Input Bias Current(Max) | 50 pA |
Iq per channel(Max) | 7.5 мА |
Iq per channel(Typ) | 5.2 мА |
Количество каналов | 1 |
Offset Drift(Typ) | 5 uV/C |
Output Current(Typ) | 80 мА |
Package Group | SC70 |
Package Size: mm2:W x L | 6SC70: 4 mm2: 2.1 x 2(SC70) PKG |
Rail-to-Rail | In to V-,Out |
Rating | Catalog |
Slew Rate(Typ) | 55 V/us |
Total Supply Voltage(Max) | 5.5 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 2.7 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 6.5 нВ/rtГц |
Vn at Flatband(Typ) | 6.4 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 6 мВ |
- Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA358 (3)
- OPA358AIDCKR OPA358AIDCKT OPA358AIDCKTG4
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > High-Speed Op Amps (>=50MHz)
