Datasheet Texas Instruments UCC383TD-3 — Даташит
Серия | UCC383 |
Модель | UCC383TD-3 |
Линейные регуляторы 3-А с низким падением напряжения 3-DDPAK/TO-263 от 0 до 70
UCC283-x, UCC383-x: Low-Dropout 3-A Linear Regulator Family datasheet
PDF, 1.1 Мб, Версия: B, Файл опубликован: 23 фев 2004
Fixed Positive LDO Regulator, 3.3V, 1V Dropout, BICMOS, PSSO3 | |||
UCC383-TD-3 | по запросу | ||
UCC383TD-3 | по запросу | ||
UCC383TD-3 Texas Instruments | по запросу | ||
UCC383TD3 | по запросу |
Pin | 3 |
Package Type | KTT |
Industry STD Term | TO-263 |
JEDEC Code | R-PSFM-G |
Width (мм) | 8.41 |
Length (мм) | 10.18 |
Thickness (мм) | 4.44 |
Pitch (мм) | 2.54 |
Max Height (мм) | 4.83 |
Mechanical Data | Скачать |
Рекомендуемая замена
Replacement | UCC383TDKTTT-3 |
Replacement Code | S |
Accuracy(%) | 2.5 |
Additional Features | Overcurrent Protection Reverse Current Protection Thermal Shutdown |
Approx. Price (US$) | 2.78 | 1ku |
Fixed Output Options(V) | 3.3 5 |
Iout(Max)(A) | 3 |
Iq(Typ)(mA) | 0.4 |
Operating Temperature Range(C) | 0 to 70 |
Output Capacitor Type | Non-Ceramic |
Output Options | Adjustable Output Fixed Output |
PSRR @ 100KHz(dB) | 18 |
Package Group | DDPAK/TO-263 |
Package Size: mm2:W x L (PKG) | See datasheet (TO-220) |
Rating | Catalog |
Regulated Outputs(#) | 1 |
Vdo(Typ)(mV) | 400 |
Vin(Max)(V) | 9 |
Vin(Min)(V) | 2.8 |
Vout(Max)(V) | 8.5 |
Vout(Min)(V) | 1.2 |
RoHS | Не совместим |
- Using LDOs and Power Managers in Systems with Redundant Power SuppliesPDF, 58 Кб, Файл опубликован: 29 ноя 2000
For reasons of continuity in some systems, independent power sources must operate in parallel. The traditional way to connect two ore more power sources in parallel uses isolation diodes. However, in situations where the associated voltage drop or the presence of voltage-feedback sensing wires makes using isolation diodes undesirable, special types of low dropout voltage regulators (LDOs) and hot- - High Current LDO Linear Reglators (UCCx81-ADJ, UCx82-ADJ, UCCx83-ADJ, UCx85-ADPDF, 56 Кб, Файл опубликован: 7 май 2002
This application provides an overview of the UCCx81-ADJ, UCCx82-ADJ, UCCx83-ADJ, UCCx84-ADJ, and UCcx85-ADJ devices.
Серия: UCC383 (18)
UCC383TD3, UCC383TD 3
