Datasheet Texas Instruments SN74LVC14ADRE4 — Даташит
Серия | SN74LVC14A |
Модель | SN74LVC14ADRE4 |
Шестигранный инвертор с триггером Шмитта 14-SOIC от -40 до 125
SNx4LVC14A Hex Schmitt-Trigger Inverters datasheet
PDF, 1.4 Мб, Версия: AA, Файл опубликован: 30 июн 2015
Купить SN74LVC14ADRE4 на РадиоЛоцман.Цены — от 7.18 до 219 ₽ 18 предложений от 11 поставщиков Микросхема: IC INV SCHMITT 6CH 1-IN 14SOIC | |||
SN74LVC14ADRE4 Texas Instruments | 7.18 ₽ | ||
SN74LVC14ADRE4 Texas Instruments | 8.71 ₽ | ||
SN74LVC14ADRE4 Texas Instruments | 22 ₽ | ||
SN74LVC14ADRE4 Texas Instruments | от 219 ₽ |
Pin | 14 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | LVC14A |
Width (мм) | 3.91 |
Length (мм) | 8.65 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Bits | 6 |
F @ Nom Voltage(Max) | 100 Mhz |
ICC @ Nom Voltage(Max) | 0.01 мА |
Output Drive (IOL/IOH)(Max) | -24/24 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 14SOIC: 52 mm2: 6 x 8.65(SOIC) PKG |
Rating | Catalog |
Schmitt Trigger | Yes |
Technology Family | LVC |
VCC(Max) | 3.6 В |
VCC(Min) | 2 В |
Voltage(Nom) | 1.8,2.5,2.7,3.3 В |
tpd @ Nom Voltage(Max) | 11,7.8,7.5,6.4 нс |
- LVC Characterization InformationPDF, 114 Кб, Файл опубликован: 1 дек 1996
This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices. - Use of the CMOS Unbuffered Inverter in Oscillator CircuitsPDF, 796 Кб, Файл опубликован: 6 ноя 2003
CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC14A (27)
- SN74LVC14AD SN74LVC14ADBLE SN74LVC14ADBR SN74LVC14ADBRE4 SN74LVC14ADBRG4 SN74LVC14ADE4 SN74LVC14ADG4 SN74LVC14ADGVR SN74LVC14ADR SN74LVC14ADRE4 SN74LVC14ADRG3 SN74LVC14ADRG4 SN74LVC14ADT SN74LVC14ADTE4 SN74LVC14ANSR SN74LVC14APW SN74LVC14APWE4 SN74LVC14APWG4 SN74LVC14APWLE SN74LVC14APWR SN74LVC14APWRE4 SN74LVC14APWRG3 SN74LVC14APWRG4 SN74LVC14APWT SN74LVC14APWTG4 SN74LVC14ARGYR SN74LVC14ARGYRG4
- Semiconductors > Logic > Buffer/Driver/Transceiver > Inverting Buffer/Driver
