Datasheet Texas Instruments SN74LVC138ADBLE — Даташит
Серия | SN74LVC138A |
Модель | SN74LVC138ADBLE |
![Datasheet Texas Instruments SN74LVC138ADBLE](http://www.ti.com/graphics/folders/partimages/SN74LVC138A.jpg)
Декодер/демультиплексор от 3 до 8 строк 16-SSOP от -40 до 85
SN74LVC138A 3-Line to 8-Line Decoders Demultiplexers datasheet
PDF, 1.5 Мб, Версия: W, Файл опубликован: 11 ноя 2016
Кодеры, декодеры, мультиплексоры и демультиплексоры Line Decoder | |||
SN74LVC138ADBLE Texas Instruments | по запросу | ||
Pin | 16 |
Package Type | DB |
Industry STD Term | SSOP |
JEDEC Code | R-PDSO-G |
Width (мм) | 5.3 |
Length (мм) | 6.2 |
Thickness (мм) | 1.95 |
Pitch (мм) | .65 |
Max Height (мм) | 2 |
Mechanical Data | Скачать |
Approx. Price (US$) | 0.10 | 1ku |
Bits(#) | 8 |
Channels(#) | 1 |
Configuration | 3:8 |
F @ Nom Voltage(Max)(Mhz) | 100 |
Function | Decoder/Demultiplexer |
ICC @ Nom Voltage(Max)(mA) | 0.01 |
Тип входа | TLL/CMOS |
Operating Temperature Range(C) | -40 to 85 |
Output Drive (IOL/IOH)(Max)(mA) | 24/-24 |
Тип выхода | CMOS |
Package Group | SSOP |
Package Size: mm2:W x L (PKG) | 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | LVC |
Тип | Standard |
VCC(Max)(V) | 3.6 |
VCC(Min)(V) | 1.65 |
Voltage(Nom)(V) | 1.8 2.5 2.7 3.3 |
tpd @ Nom Voltage(Max)(ns) | 22 9.9 7.9 6.7 |
RoHS | Не совместим |
- LVC Characterization InformationPDF, 114 Кб, Файл опубликован: 1 дек 1996
This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices. - Use of the CMOS Unbuffered Inverter in Oscillator CircuitsPDF, 796 Кб, Файл опубликован: 6 ноя 2003
CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC138A (27)
- SN74LVC138AD SN74LVC138ADBLE SN74LVC138ADBR SN74LVC138ADBRE4 SN74LVC138ADBRG4 SN74LVC138ADE4 SN74LVC138ADG4 SN74LVC138ADGVR SN74LVC138ADR SN74LVC138ADRE4 SN74LVC138ADRG4 SN74LVC138ADT SN74LVC138AGQNR SN74LVC138ANSR SN74LVC138ANSRG4 SN74LVC138APW SN74LVC138APWE4 SN74LVC138APWG4 SN74LVC138APWLE SN74LVC138APWR SN74LVC138APWRE4 SN74LVC138APWRG4 SN74LVC138APWT SN74LVC138ARGYR SN74LVC138ARGYRG4 SN74LVC138ARSVR SN74LVC138AZQNR
- Semiconductors > Logic > Specialty Logic > Decoder/Encoder/Multiplexer
