Datasheet Texas Instruments DAC8820ICDBG4 — Даташит
Серия | DAC8820 |
Модель | DAC8820ICDBG4 |
16-битный ЦАП с умножением на параллельный вход 28-SSOP от -40 до 85
16-Bit, Parallel Input Multiplying Digital-to-Analog Converter datasheet
PDF, 1.2 Мб, Версия: D, Файл опубликован: 19 фев 2008
Купить DAC8820ICDBG4 на РадиоЛоцман.Цены — от 966 до 1 669 ₽ 13 предложений от 10 поставщиков TEXAS INSTRUMENTS DAC8820ICDBG4 Digital to Analogue Converter, 16Bit, 2MSPS, Parallel, 2.7V to 5.5V, SSOP, 28Pins | |||
DAC8820ICDBG4 Texas Instruments | 966 ₽ | ||
DAC8820ICDBG4 Texas Instruments | 1 320 ₽ | ||
DAC8820ICDBG4 Texas Instruments | по запросу | ||
Pin | 28 |
Package Type | DB |
Industry STD Term | SSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 50 |
Carrier | TUBE |
Маркировка | DAC8820 |
Width (мм) | 5.3 |
Length (мм) | 10.2 |
Thickness (мм) | 1.95 |
Pitch (мм) | .65 |
Max Height (мм) | 2 |
Mechanical Data | Скачать |
Code to Code Glitch(Typ) | 2 nV-sec |
DAC Architecture | Multiplying DAC |
DAC Channels | 1 |
Gain Error(Max) | 0.02 %FSR |
INL(Max) | 1 +/-LSB |
Interface | Parallel |
Offset Error(Max) | N/A % |
Output Range Max. | 2 mA/V |
Тип выхода | Unbuffered Current |
Package Group | SSOP |
Package Size: mm2:W x L | 28SSOP: 80 mm2: 7.8 x 10.2(SSOP) PKG |
Power Consumption(Typ) | 0.025 mW |
Rating | Catalog |
Reference: Type | Ext |
Разрешение | 16 Bits |
Sample / Update Rate | 2 MSPS |
Время установления | 0.5 µs |
Special Features | N/A |
Zero Code Error(Typ) | N/A мВ |
- Evaluation Modules & Boards: DAC8820EVM
DAC8820EVM Evaluation Module
- Interfacing the DAC8806 and DAC8820 to TMS320 DSPsPDF, 61 Кб, Файл опубликован: 20 дек 2006
This application report presents a method for interfacing the DAC8806 and DAC8820 - single-channel, current-output, 14-/16-bit multiplying digital-to-analog converters - to the TMS320 series of digital signal processors. The software developed for this application report creates a 256-point sine table, and then continuously writes values from the sine table to the DAC8806/20EVM to create a +/-10-V - Interfacing the DAC8806 and DAC8820 to MSP430 MicrocontrollersPDF, 53 Кб, Файл опубликован: 20 дек 2006
This application report presents a method for interfacing the DAC8806 and DAC8820 single-channel, current-output, 14-/16-bit multiplying digital-to-analog converters — to the MSP430F449 processor using the SoftBaugh HPA449 evaluation system. The associated software creates a 256-point sine table, and then continuously writes values from the sine table to the DAC8806/20EVM, which outputs a 10V sin
Серия: DAC8820 (5)
- DAC8820IBDB DAC8820IBDBR DAC8820ICDB DAC8820ICDBG4 DAC8820ICDBR
- Semiconductors > Data Converters > Digital-to-Analog Converters (DACs) > Precision DACs (=<10MSPS)
