Datasheet Texas Instruments SN74LVCH16245AGQLR — Даташит
Серия | SN74LVCH16245A |
Модель | SN74LVCH16245AGQLR |
16-битный шинный трансивер с выходами с 3 состояниями 56 BGA MICROSTAR JUNIOR от -40 до 85
SN74LVCH16245A 16-bit Bus Transceiver With 3-state Outputs datasheet
PDF, 1.0 Мб, Версия: C, Файл опубликован: 7 ноя 2013
Купить SN74LVCH16245AGQLR на РадиоЛоцман.Цены — от 56 до 107 ₽ 14 предложений от 11 поставщиков Transceiver, Non-Inverting 2 Element 8 Bit per Element 3-State Output 56-BGA Microstar Junior (7x4.5) | |||
SN74LVCH16245AGQLR Texas Instruments | от 56 ₽ | ||
SN74LVCH16245AGQLR Texas Instruments | 71 ₽ | ||
SN74LVCH16245AGQLR Texas Instruments | по запросу | ||
Pin | 56 |
Package Type | GQL |
Industry STD Term | BGA MICROSTAR JUNIOR |
JEDEC Code | R-PBGA-N |
Маркировка | LDH245A |
Width (мм) | 4.5 |
Length (мм) | 7 |
Thickness (мм) | .75 |
Pitch (мм) | .65 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
Рекомендуемая замена
Replacement | SN74LVCH16245AZQLR |
Replacement Code | P |
Approx. Price (US$) | 0.45 | 1ku |
Bits(#) | 16 |
F @ Nom Voltage(Max)(Mhz) | 100 |
ICC @ Nom Voltage(Max)(mA) | 0.02 |
Тип входа | TTL/CMOS |
Operating Temperature Range(C) | -40 to 125 -40 to 85 |
Output Drive (IOL/IOH)(Max)(mA) | -24/24 |
Тип выхода | LVTTL |
Package Group | BGA MICROSTAR JUNIOR |
Package Size: mm2:W x L (PKG) | 56BGA MICROSTAR JUNIOR: 32 mm2: 4.5 x 7(BGA MICROSTAR JUNIOR) |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | LVC |
VCC(Max)(V) | 3.6 |
VCC(Min)(V) | 1.65 |
Voltage(Nom)(V) | 1.8 2.5 2.7 3.3 |
tpd @ Nom Voltage(Max)(ns) | 7.1 4.5 4.7 4 |
RoHS | Не совместим |
- Bus-Hold CircuitPDF, 418 Кб, Файл опубликован: 5 фев 2001
When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of
Серия: SN74LVCH16245A (11)
- Semiconductors > Logic > Buffer/Driver/Transceiver > Standard Transceiver
