Datasheet Texas Instruments SN74AUCH16244ZQLR — Даташит
Серия | SN74AUCH16244 |
Модель | SN74AUCH16244ZQLR |
16-битный буфер/драйвер с выходами с 3 состояниями 56-BGA MICROSTAR JUNIOR от -40 до 85
SN74AUCH16244 datasheet
PDF, 852 Кб, Версия: E, Файл опубликован: 1 ноя 2002
Купить SN74AUCH16244ZQLR на РадиоЛоцман.Цены — от 117 до 245 ₽ 8 предложений от 8 поставщиков Buffer, Non-Inverting 4 Element 4 Bit per Element 3-State Output 56-BGA Microstar Junior (7x4.5) | |||
SN74AUCH16244ZQLR Texas Instruments | 117 ₽ | ||
SN74AUCH16244ZQLR Texas Instruments | 166 ₽ | ||
SN74AUCH16244ZQLR Texas Instruments | 243 ₽ | ||
SN74AUCH16244ZQLR | по запросу |
Pin | 56 |
Package Type | ZQL |
Industry STD Term | BGA MICROSTAR JUNIOR |
JEDEC Code | R-PBGA-N |
Package QTY | 1000 |
Carrier | LARGE T&R |
Маркировка | MJ244 |
Width (мм) | 4.5 |
Length (мм) | 7 |
Thickness (мм) | .75 |
Pitch (мм) | .65 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
Bits | 16 |
F @ Nom Voltage(Max) | 250 Mhz |
ICC @ Nom Voltage(Max) | 0.02 мА |
Output Drive (IOL/IOH)(Max) | -9/9 мА |
Package Group | BGA MICROSTAR JUNIOR |
Package Size: mm2:W x L | 56BGA MICROSTAR JUNIOR: 32 mm2: 4.5 x 7(BGA MICROSTAR JUNIOR) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | AUC |
VCC(Max) | 2.7 В |
VCC(Min) | 0.8 В |
Voltage(Nom) | 0.8,1.2,1.5,1.8,2.5 В |
tpd @ Nom Voltage(Max) | 5.4,2.8,1.9,1.8 нс |
- Designing With TI Ultra-Low-Voltage CMOS (AUC) Octals and Widebus DevicesPDF, 374 Кб, Файл опубликован: 21 мар 2003
System designers are continuously seeking ways to improve signal integrity, increase speed, and reduce power consumption in personal computers, telecommunication equipment, and other electronic systems. The Texas Instruments (TI) next-generation Advanced Ultra-low-voltage CMOS (AUC) octals and Widebus(TM) devices are designed to achieve these goals. These devices are designed for a 0.8-V to 2.7-V
Серия: SN74AUCH16244 (4)
- SN74AUCH16244DGGR SN74AUCH16244DGVR SN74AUCH16244GQLR SN74AUCH16244ZQLR
- Semiconductors > Logic > Buffer/Driver/Transceiver > Non-Inverting Buffer/Driver
