Datasheet Texas Instruments INA115BUG4 — Даташит
Серия | INA115 |
Модель | INA115BUG4 |
Прецизионный инструментальный усилитель 16-SOIC
Precision Instrumentation Amplifier datasheet
PDF, 724 Кб, Файл опубликован: 27 сен 2000
Купить INA115BUG4 на РадиоЛоцман.Цены — от 495 до 1 079 ₽ 13 предложений от 10 поставщиков Instrumentation Amplifier 1 Circuit 16-SOIC | |||
INA115BUG4 Texas Instruments | 495 ₽ | ||
INA115BUG4 Texas Instruments | от 509 ₽ | ||
INA115BUG4 Texas Instruments | 825 ₽ | ||
INA115BUG4 Texas Instruments | по запросу |
Pin | 16 |
Package Type | DW |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 40 |
Carrier | TUBE |
Маркировка | INA115BU |
Width (мм) | 7.5 |
Length (мм) | 10.3 |
Thickness (мм) | 2.35 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2.65 |
Mechanical Data | Скачать |
Bandwidth at Min Gain(Typ) | 1 МГц |
CMRR(Min) | 110 дБ |
Gain Error (+/-)(Max) | 2 % |
Gain Non-Linearity (+/-)(Max) | 0.002 % |
Gain(Max) | 10000 V/V |
Gain(Min) | 1 V/V |
Input Bias Current (+/-)(Max) | 2 нА |
Input Offset (+/-)(Max) | 50 uV |
Input Offset Drift (+/-)(Max) | 0.25 uV/C |
Iq(Typ) | 2.2 мА |
Noise at 0.1 Hz - 10 Hz(Typ) | 0.4 uVpp |
Noise at 1kHz(Typ)(nV/rt | 11 Hz |
Количество каналов | 1 |
Package Group | SOIC |
Package Size: mm2:W x L | 16SOIC: 106 mm2: 10.3 x 10.3(SOIC) PKG |
Rating | Catalog |
Vs(Max) | 36 В |
Vs(Min) | 4.5 В |
- Programmable-Gain Instrumentation AmplifiersPDF, 47 Кб, Файл опубликован: 27 сен 2000
The INA115 is a precision instrumentation amplifier (IA). Its gain-sense and amplifier output connections are available so that gains can be accurately set using external resistors. By adding switches or a multiplexer, you can make a precision programmable-gain IA (PGIA). Using the circuit topology shown in this bulletin, the switches are in series with op amp inputs so their resistance does not a
Серия: INA115 (4)
- INA115AU INA115AU/1K INA115BU INA115BUG4
- Semiconductors > Amplifiers > Instrumentation Amplifiers
