Datasheet Texas Instruments 85084012A — Даташит
Серия | SN54LS145 |
Модель | 85084012A |
Декодеры/драйверы BCD в десятичные числа 20-LCCC от -55 до 125
BCD to Decimal Decoders/Drivers datasheet
PDF, 1.1 Мб, Версия: A, Файл опубликован: 1 мар 1974
Купить 85084012A на РадиоЛоцман.Цены — от 2 716 до 2 819 ₽ 6 предложений от 6 поставщиков INTERCONNECTS .050?€? Grid Headers and Sockets Single and Double Row | |||
85084012A Texas Instruments | 2 716 ₽ | ||
85084012A Texas Instruments | 2 757 ₽ | ||
85084012A Texas Instruments | по запросу | ||
85084012A | по запросу |
Pin | 20 | 20 | 20 |
Package Type | FK | FK | FK |
Industry STD Term | LCCC | LCCC | LCCC |
JEDEC Code | S-CQCC-N | S-CQCC-N | S-CQCC-N |
Package QTY | 1 | 1 | 1 |
Carrier | TUBE | TUBE | TUBE |
Маркировка | 145FK | 85084012A | SNJ54LS |
Width (мм) | 8.89 | 8.89 | 8.89 |
Length (мм) | 8.89 | 8.89 | 8.89 |
Thickness (мм) | 1.83 | 1.83 | 1.83 |
Pitch (мм) | 1.27 | 1.27 | 1.27 |
Max Height (мм) | 2.03 | 2.03 | 2.03 |
Количество каналов | 1 |
F @ Nom Voltage(Max) | 35 Mhz |
ICC @ Nom Voltage(Max) | 13 мА |
Package Group | LCCC |
Package Size: mm2:W x L | 20LCCC: 79 mm2: 8.89 x 8.89(LCCC) PKG |
Rating | Military |
Schmitt Trigger | No |
Technology Family | LS |
VCC(Max) | 5.5 В |
VCC(Min) | 4.5 В |
Voltage(Nom) | 5 В |
tpd @ Nom Voltage(Max) | 50 нс |
RoHS | See ti.com |
- Input and Output Characteristics of Digital Integrated CircuitsPDF, 1.7 Мб, Файл опубликован: 1 окт 1996
This report contains a comprehensive collection of the input and output characteristic curves of typical integrated circuits from various logic families. These curves go beyond the information given in data sheets by providing additional details regarding the characteristics of the components. This knowledge is particularly useful when for example a decision must be made as to which circuit shou - Designing With Logic (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 1 июн 1997
Data sheets which usually give information on device behavior only under recommended operating conditions may only partially answer engineering questions that arise during the development of systems using logic devices. However information is frequently needed regarding the behavior of the device outside the conditions in the data sheet. Such questions might be:?How does a bus driver behave w - Designing with the SN54/74LS123 (Rev. A)PDF, 118 Кб, Версия: A, Файл опубликован: 1 мар 1997
Серия: SN54LS145 (7)
- Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Decoders/Encoders/Multiplexers
