Datasheet Texas Instruments SN74AS245DWRG4 — Даташит
Серия | SN74AS245 |
Модель | SN74AS245DWRG4 |
Восьмеричные шинные трансиверы с выходами с 3 состояниями 20-SOIC от 0 до 70
SN54ALS245A, SN54AS245, SN74ALS245A, SN74AS245 datasheet
PDF, 1.3 Мб, Версия: A, Файл опубликован: 13 янв 2003
7 предложений от 7 поставщиков Transceiver, Non-Inverting 1 Element 8 Bit per Element 3-State Output 20-SOIC | |||
SN74AS245DWRG4 Texas Instruments | 72 ₽ | ||
SN74AS245DWRG4 Texas Instruments | по запросу | ||
SN74AS245DWRG4 | по запросу | ||
Pin | 20 |
Package Type | DW |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Width (мм) | 7.5 |
Length (мм) | 12.8 |
Thickness (мм) | 2.35 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2.65 |
Mechanical Data | Скачать |
Approx. Price (US$) | 1.77 | 1ku |
Bits(#) | 8 |
F @ Nom Voltage(Max)(Mhz) | 125 |
ICC @ Nom Voltage(Max)(mA) | 0.055 |
Тип входа | TTL |
Operating Temperature Range(C) | 0 to 70 |
Output Drive (IOL/IOH)(Max)(mA) | -15/64 |
Тип выхода | TTL |
Package Group | SOIC |
Package Size: mm2:W x L (PKG) | See datasheet (PDIP) |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | AS |
VCC(Max)(V) | 5.5 |
VCC(Min)(V) | 4.5 |
Voltage(Nom)(V) | 5 |
tpd @ Nom Voltage(Max)(ns) | 10 |
RoHS | Не совместим |
- Advanced Schottky Load ManagementPDF, 277 Кб, Файл опубликован: 1 фев 1997
Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme - Advanced Schottky (ALS and AS) Logic FamiliesPDF, 1.9 Мб, Файл опубликован: 1 авг 1995
Серия: SN74AS245 (6)
- SN74AS245DW SN74AS245DWR SN74AS245DWRE4 SN74AS245DWRG4 SN74AS245N SN74AS245NSR
- Semiconductors > Logic > Buffer/Driver/Transceiver > Standard Transceiver
