Datasheet Texas Instruments SN74AVC2T872YFPR — Даташит
Серия | SN74AVC2T872 |
Модель | SN74AVC2T872YFPR |
![Datasheet Texas Instruments SN74AVC2T872YFPR](http://www.ti.com/graphics/folders/partimages/SN74AVC2T872.jpg)
Переключатель уровня напряжения для интерфейса IC-USB 12-DSBGA от -40 до 85
2-Bit Voltage-Level Shifter For IC-USB Interface datasheet
PDF, 786 Кб, Файл опубликован: 24 ноя 2008
![]() 17 предложений от 13 поставщиков Voltage Level Translator Bidirectional 1 Circuit 2 Channel 12-DSBGA (1.16x1.56) | |||
SN74AVC2T872YFPR Texas Instruments | 27 ₽ | ||
SN74AVC2T872YFPR Texas Instruments | 29 ₽ | ||
SN74AVC2T872YFPR Texas Instruments | по запросу | ||
SN74AVC2T872YFPR | по запросу |
Pin | 12 | 12 |
Package Type | YFP | YFP |
Industry STD Term | DSBGA | DSBGA |
JEDEC Code | R-XBGA-N | R-XBGA-N |
Package QTY | 3000 | 3000 |
Carrier | LARGE T&R | LARGE T&R |
Маркировка | TU2 | TUN |
Pitch (мм) | .4 | .4 |
Max Height (мм) | .5 | .5 |
3-State Output | No |
Bits | 2 |
F @ Nom Voltage(Max) | 6 Mhz |
Gate Type | TRANSCEIVER |
ICC @ Nom Voltage(Max) | 0.01 мА |
Logic | True |
Output Drive (IOL/IOH)(Max) | 12/-12 мА |
Package Group | DSBGA |
Package Size: mm2:W x L | See datasheet (DSBGA) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Special Features | Interchip USB |
Sub-Family | Dual Supply Translator |
Technology Family | AVC |
VCC(Max) | 3.6 В |
VCC(Min) | 1.1 В |
Voltage(Nom) | 1.2,1.5,1.8,2.5,3.3 В |
tpd @ Nom Voltage(Max) | 22,16,14,12,11 нс |
- Dynamic Output Control (DOC) Circuitry Technology And Applications (Rev. B)PDF, 126 Кб, Версия: B, Файл опубликован: 7 июл 1999
Texas Instruments (TI[TM]) next-generation logic is called the Advanced Very-low-voltage CMOS (AVC) family. The AVCfamily features TI?s Dynamic Output Control (DOC[TM]) circuit (patent pending). DOC circuitry automatically lowers the outputimpedance of the circuit at the beginning of a signal transition, providing enough current to achieve high signaling speeds, thensubsequently raises the i - AVC Logic Family Technology and Applications (Rev. A)PDF, 148 Кб, Версия: A, Файл опубликован: 26 авг 1998
Texas Instruments (TI?) announces the industry?s first logic family to achieve maximum propagation delays of less than 2 ns at 2.5 V. TI?s next-generation logic is the Advanced Very-low-voltage CMOS (AVC) family. Although optimized for 2.5-V systems, AVC logic supports mixed-voltage systems because it is compatible with 3.3-V and 1.8-V devices. The AVC family features TI?s Dynamic Output Control ( - Voltage Translation Between 3.3-V, 2.5-V, 1.8-V, and 1.5-V Logic Standards (Rev. B)PDF, 390 Кб, Версия: B, Файл опубликован: 30 апр 2015
- 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
Серия: SN74AVC2T872 (1)
- SN74AVC2T872YFPR
- Semiconductors > Logic > Little Logic
