Datasheet Texas Instruments 5962-9203103Q2A — Даташит
Серия | UC1863 |
Модель | 5962-9203103Q2A |
Резонансные контроллеры источников питания 20-LCCC от -55 до 125
Resonant-Mode Power Supply Controllers datasheet
PDF, 3.9 Мб, Версия: B, Файл опубликован: 13 сен 2007
Купить 5962-9203103Q2A на РадиоЛоцман.Цены — от 5 514 до 5 560 ₽ Resonant-Mode Power Supply Controllers 20-LCCC -55 to 125 | |||
5962-9203103Q2A Texas Instruments | 5 514 ₽ | ||
5962-9203103Q2A Texas Instruments | 5 560 ₽ | ||
5962-9203103Q2A Texas Instruments | по запросу |
Pin | 20 |
Package Type | FK |
Industry STD Term | LCCC |
JEDEC Code | S-CQCC-N |
Package QTY | 1 |
Carrier | TUBE |
Width (мм) | 8.89 |
Length (мм) | 8.89 |
Thickness (мм) | 1.83 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2.03 |
Mechanical Data | Скачать |
Control Method | Voltage |
Duty Cycle(Max) | 50 % |
Основные особенности | Error Amplifier,Soft Start,Soft Switching,Multi-topology |
Frequency(Max) | 500 kHz |
Frequency(Min) | 50 kHz |
Package Group | LCCC |
Package Size: mm2:W x L | 20LCCC: 79 mm2: 8.89 x 8.89(LCCC) PKG |
Rating | Military |
Topology | Full-Bridge,Half-Bridge,Push-Pull |
UVLO Thresholds On/Off | 8/7 В |
Vin(Max) | 22 В |
Vin(Min) | 7 В |
RoHS | See ti.com |
- U-138 Zero Voltage Switching Resonant Power ConversionPDF, 794 Кб, Файл опубликован: 5 сен 1999
This application note explores the technique of zero voltage switching in modern power conversion. It describes several ZVS topologies and applications limitations of the ZVS technique and a generalized design procedure. Two design examples are presented: a 50W DC/DC converter and an off-line 300W multiple output power supply. This discussion concludes with a performance comparison of ZVS conve - U-122 A New Family of Integrated Circuits Controls Resonant Mode PowerPDF, 272 Кб, Файл опубликован: 5 сен 1999
This application note introduces the UC3861-8 family of ICs which are optimized for the control of zero-current-switched and zero-voltage-switched quasi-resonant converters. Differences among members of this device family result from the various combinations of UVLO thresholds and output options. The one-shot pulse steering logic is configured to program either on time for ZCS systems (UC1865-186
Серия: UC1863 (6)
- 5962-9203103Q2A 5962-9203103QEA UC1863J UC1863J883B UC1863L UC1863L883B
- Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
59629203103Q2A, 5962 9203103Q2A
