Datasheet Texas Instruments CD74ACT574E — Даташит
Серия | CD74ACT574 |
Модель | CD74ACT574E |
Восьмеричные неинвертирующие триггеры D-типа с выходами с 3 состояниями 20-PDIP от -55 до 125
Octal D-Type Flip-Flop, 3-State datasheet
PDF, 1.3 Мб, Файл опубликован: 3 дек 1998
Купить CD74ACT574E на РадиоЛоцман.Цены — от 9.00 до 337 ₽ 30 предложений от 23 поставщиков TEXAS INSTRUMENTS CD74ACT574E Flip-Flop, Tri State Non Inverted, Positive Edge, 74ACT574, D, 11.2ns, 110MHz, 24mA, DIP | |||
74ACT574M (CD74ACT574M) so20 | 9.00 ₽ | ||
CD74ACT574E Texas Instruments | 19 ₽ | ||
CD74ACT574M96 Texas Instruments | по запросу | ||
CD74ACT574EX Texas Instruments | по запросу |
Pin | 20 |
Package Type | N |
Industry STD Term | PDIP |
JEDEC Code | R-PDIP-T |
Package QTY | 20 |
Carrier | TUBE |
Маркировка | CD74ACT574E |
Width (мм) | 6.35 |
Length (мм) | 24.33 |
Thickness (мм) | 4.57 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
3-State Output | Yes |
Bits | 8 |
F @ Nom Voltage(Max) | 90 Mhz |
ICC @ Nom Voltage(Max) | 0.04 мА |
Output Drive (IOL/IOH)(Max) | 24/-24 мА |
Package Group | PDIP |
Package Size: mm2:W x L | See datasheet (PDIP) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | ACT |
VCC(Max) | 5.5 В |
VCC(Min) | 4.5 В |
Voltage(Nom) | 5 В |
tpd @ Nom Voltage(Max) | 12 нс |
Бессвинцовая технология (Pb Free) | Да |
- Selecting the Right Level Translation Solution (Rev. A)PDF, 313 Кб, Версия: A, Файл опубликован: 22 июн 2004
Supply voltages continue to migrate to lower nodes to support today's low-power high-performance applications. While some devices are capable of running at lower supply nodes others might not have this capability. To haveswitching compatibility between these devices the output of each driver must be compliant with the input of the receiver that it is driving. There are several level-translati - Power-Up Behavior of Clocked Devices (Rev. A)PDF, 34 Кб, Версия: A, Файл опубликован: 6 фев 2015
- Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Серия: CD74ACT574 (8)
- Semiconductors > Logic > Flip-Flop/Latch/Register > D-Type Flip-Flop
