Datasheet Texas Instruments TUSB546-DCIRNQT — Даташит
Серия | TUSB546-DCI |
Модель | TUSB546-DCIRNQT |
USB Type-C DP ALT Mode Linear Redriver Crosspoint Switch 40-WQFN 0 to 70
TUSB546-DCI USB Type-Cв„ў DP ALT Mode Linear Redriver Crosspoint Switch datasheet
PDF, 1.8 Мб, Версия: B, Файл опубликован: 6 июн 2017
Купить TUSB546-DCIRNQT на РадиоЛоцман.Цены — от 328 до 970 ₽ 13 предложений от 9 поставщиков USB интерфейс, Линейный Редрайвер Протокола USB Type-C, USB 3.1, 3 В, 3.6 В, WQFN, 40 вывод(-ов) | |||
TUSB546-DCIRNQT Texas Instruments | 328 ₽ | ||
TUSB546-DCIRNQT Texas Instruments | 364 ₽ | ||
TUSB546-DCIRNQT Texas Instruments | 391 ₽ | ||
TUSB546-DCIRNQT Texas Instruments | по запросу |
Pin | 40 |
Package Type | RNQ |
Industry STD Term | WQFN |
JEDEC Code | R-PQFP-N |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | TUSB546D |
Width (мм) | 4 |
Length (мм) | 6 |
Thickness (мм) | .75 |
Pitch (мм) | .4 |
Max Height (мм) | .8 |
Mechanical Data | Скачать |
Alternate Mode | Yes |
Configuration | Alternate mode / Source |
Data Role | DFP |
Dead Battery Support | No |
External Power Path Control | N/A |
Function | Active Signal Switch |
Internal Power Path | N/A |
Рабочий диапазон температур | от 0 до 70 C |
Package Group | WQFN |
Policy Manager | N/A |
Power Role | N/A |
Rating | Catalog |
Realtime VBUS monitoring | No |
USB Speed | 5000 Mbps |
- Evaluation Modules & Boards: TUSB546EVM
TUSB546 USB Type-CВ™ Alternate Mode Redriver Switch EVM
- Enabling HDMI over Type-C using TUSB564A-DCIPDF, 141 Кб, Файл опубликован: 12 сен 2017
The TUSB546A-DCI is a linear redriver that supports both USB3.1 Gen1 and DisplayPort 1.4 over a USB Type-C interface.Even though the TUSB546A-DCI was released for the DisplayPort Alternate mode, the TUSB546A-DCI can also be used as a redriver in a USB-C HDMI Alternate mode source application. This document is intended to describe how to use the TUSB546A-DCI in a HDMI Type-C source application. T - TUSB546-DCI in a DisplayPort ApplicationPDF, 355 Кб, Файл опубликован: 8 ноя 2016
The TUSB546-DCI is a linear redriver that supports both USB3.1 Gen1 and DisplayPort 1.4 over a Type-C interface. Even though the TUSB546-DCI is released for the Type-C market, the TUSB546-DCI can also be used as a standalone redriver for DisplayPort applications. This application report describes how to use the TUSB546-DCI in a DisplayPort application. The information in this document can also be
Серия: TUSB546-DCI (2)
- TUSB546-DCIRNQR TUSB546-DCIRNQT
- Semiconductors > Interface > USB > USB Type-C and Power Delivery
TUSB546DCIRNQT, TUSB546 DCIRNQT
