Datasheet Texas Instruments SN74LVC1G74DCURG4 — Даташит
Серия | SN74LVC1G74 |
Модель | SN74LVC1G74DCURG4 |
Одиночный триггер D-типа, запускаемый по положительному фронту, со сбросом и предустановкой 8-VSSOP от -40 до 125
SN74LVC1G74 Single Positive-Edge-Triggered D-Type Flip-Flop with Clear and Preset datasheet
PDF, 1.3 Мб, Версия: E, Файл опубликован: 25 янв 2015
Купить SN74LVC1G74DCURG4 на РадиоЛоцман.Цены — от 15 до 55 ₽ 13 предложений от 10 поставщиков Single Positive-Edge-Triggered D-Type Flip-Flop With Clear and Preset 8-VSSOP -40 to 125 | |||
SN74LVC1G74DCURG4 Texas Instruments | 15 ₽ | ||
SN74LVC1G74DCURG4 Texas Instruments | 17 ₽ | ||
SN74LVC1G74DCURG4 Texas Instruments | 27 ₽ | ||
SN74LVC1G74DCURG4 Texas Instruments | по запросу |
Pin | 8 |
Package Type | DCU |
Industry STD Term | VSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | N74R |
Width (мм) | 2 |
Length (мм) | 2.3 |
Thickness (мм) | .85 |
Pitch (мм) | .5 |
Max Height (мм) | .9 |
Mechanical Data | Скачать |
3-State Output | No |
Bits | 1 |
F @ Nom Voltage(Max) | 150 Mhz |
Gate Type | FLIP-FLOP |
ICC @ Nom Voltage(Max) | 0.01 мА |
Logic | True |
Output Drive (IOL/IOH)(Max) | 32/-32 мА |
Package Group | VSSOP |
Package Size: mm2:W x L | 8VSSOP: 6 mm2: 3.1 x 2(VSSOP) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Special Features | Ioff,down translation to Vcc,low power |
Sub-Family | D-Type Flip-Flop |
Technology Family | LVC |
VCC(Max) | 5.5 В |
VCC(Min) | 1.65 В |
Voltage(Nom) | 1.8,2.5,3.3,5 В |
tpd @ Nom Voltage(Max) | 13.4,7.1,5.9,4.1 нс |
- LVC Characterization InformationPDF, 114 Кб, Файл опубликован: 1 дек 1996
This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices. - Use of the CMOS Unbuffered Inverter in Oscillator CircuitsPDF, 796 Кб, Файл опубликован: 6 ноя 2003
CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC1G74 (7)
- SN74LVC1G74DCTR SN74LVC1G74DCUR SN74LVC1G74DCURG4 SN74LVC1G74DCUT SN74LVC1G74DQER SN74LVC1G74RSE2 SN74LVC1G74RSER
- Semiconductors > Logic > Little Logic
