Datasheet Texas Instruments TUSB1046-DCIRNQT — Даташит
Серия | TUSB1046-DCI |
Модель | TUSB1046-DCIRNQT |
Режим USB Type-C DP ALT, перекрестный коммутатор с линейным драйвером 10 Гбит/с 40-WQFN 0–70
TUSB1046-DCI USB Type-Cв„ў DisplayPortв„ў ALT Mode 10 Gbps Linear Redriver Crosspoint Switch datasheet
PDF, 1.8 Мб, Версия: B, Файл опубликован: 6 июн 2017
Купить TUSB1046-DCIRNQT на РадиоЛоцман.Цены — от 463 до 1 425 ₽ 16 предложений от 9 поставщиков TEXAS INSTRUMENTS TUSB1046-DCIRNQT USB Interface, Switch, USB 3.1, 3 V, 3.6 V, WQFN, 40 PinsNew | |||
TUSB1046-DCIRNQT Texas Instruments | 463 ₽ | ||
TUSB1046-DCIRNQT Texas Instruments | 475 ₽ | ||
TUSB1046-DCIRNQT Texas Instruments | 499 ₽ | ||
TUSB1046-DCIRNQT Texas Instruments | по запросу |
Pin | 40 |
Package Type | RNQ |
Industry STD Term | WQFN |
JEDEC Code | R-PQFP-N |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | TUSB46D |
Width (мм) | 4 |
Length (мм) | 6 |
Thickness (мм) | .75 |
Pitch (мм) | .4 |
Max Height (мм) | .8 |
Mechanical Data | Скачать |
Alternate Mode | Yes |
Configuration | Alternate mode / Source |
Data Role | DFP |
External Power Path Control | N/A |
Function | Active Signal Switch |
Internal Power Path | N/A |
Рабочий диапазон температур | от 0 до 70 C |
Package Group | WQFN |
Policy Manager | N/A |
Power Role | N/A |
Rating | Catalog |
Realtime VBUS monitoring | No |
USB Speed | 10000 Mbps |
- Evaluation Modules & Boards: TUSB1046EVM
TUSB1046 USB Type-CВ™ Alternate Mode Redriver Switch EVM
- Enabling HDMI over Type-C using TUSB564A-DCIPDF, 141 Кб, Файл опубликован: 12 сен 2017
The TUSB546A-DCI is a linear redriver that supports both USB3.1 Gen1 and DisplayPort 1.4 over a USB Type-C interface.Even though the TUSB546A-DCI was released for the DisplayPort Alternate mode, the TUSB546A-DCI can also be used as a redriver in a USB-C HDMI Alternate mode source application. This document is intended to describe how to use the TUSB546A-DCI in a HDMI Type-C source application. T - TUSB546-DCI in a DisplayPort ApplicationPDF, 355 Кб, Файл опубликован: 8 ноя 2016
The TUSB546-DCI is a linear redriver that supports both USB3.1 Gen1 and DisplayPort 1.4 over a Type-C interface. Even though the TUSB546-DCI is released for the Type-C market, the TUSB546-DCI can also be used as a standalone redriver for DisplayPort applications. This application report describes how to use the TUSB546-DCI in a DisplayPort application. The information in this document can also be
Серия: TUSB1046-DCI (2)
- TUSB1046-DCIRNQR TUSB1046-DCIRNQT
- Semiconductors > Interface > USB > USB Type-C and Power Delivery
TUSB1046DCIRNQT, TUSB1046 DCIRNQT
