Datasheet Texas Instruments TLC2654Q-8D — Даташит
Серия | TLC2654 |
Модель | TLC2654Q-8D |
Малошумящий операционный усилитель с прерывателем 8-SOIC от -40 до 125
Advanced LinCMOS Low-Noise Chopper Stabilized Operational Amplifiers datasheet
PDF, 1.2 Мб, Версия: G, Файл опубликован: 25 апр 2001
Купить TLC2654Q-8D на РадиоЛоцман.Цены — от 71 до 539 ₽ 9 предложений от 8 поставщиков Микросхема: IC OPAMP GP 1 CIRCUIT 8SOIC | |||
TLC2654Q-8D Texas Instruments | 71 ₽ | ||
TLC2654Q-8D Texas Instruments | 216 ₽ | ||
TLC2654Q-8D Texas Instruments | 275 ₽ | ||
TLC2654Q-8D | по запросу |
Pin | 8 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Width (мм) | 3.91 |
Length (мм) | 4.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Additional Features | Zero Drift |
Approx. Price (US$) | 1.78 | 1ku |
Архитектура | CMOS |
CMRR(Min)(dB) | 105 |
CMRR(Typ)(dB) | 125 |
GBW(Typ)(MHz) | 1.9 |
Input Bias Current(Max)(pA) | 60 |
Iq per channel(Max)(mA) | 2.4 |
Iq per channel(Typ)(mA) | 1.5 |
Number of Channels(#) | 1 |
Offset Drift(Typ)(uV/C) | 0.01 |
Operating Temperature Range(C) | -40 to 85 0 to 70 |
Output Current(Typ)(mA) | 3 |
Package Group | SOIC |
Package Size: mm2:W x L (PKG) | See datasheet (PDIP) |
Rail-to-Rail | In to V- Out |
Rating | Catalog |
Slew Rate(Typ)(V/us) | 2.8 |
Total Supply Voltage(Max)(+5V=5, +/-5V=10) | 16 |
Total Supply Voltage(Min)(+5V=5, +/-5V=10) | 4.6 |
Vn at 1kHz(Typ)(nV/rtHz) | 23 |
Vos (Offset Voltage @ 25C)(Max)(mV) | 0.02 |
RoHS | Не совместим |
- Choosing an ADC and Op Amp for Minimum OffsetPDF, 72 Кб, Файл опубликован: 28 окт 1999
Designing a mixed-signal circuit containing analog and digital components can be a challenge to the development engineer. Requirements such as a low single-polarity supply voltage and a high degree of precision may conflict, and make the choice of components and the best circuit design difficult. This report discusses problems that arise in using operational amplifiers (op amps) for signal conditi - DC Parameters: Input Offset VoltagePDF, 295 Кб, Файл опубликован: 27 мар 2001
The input offset voltage, VIO, is a common dc parameter in operational amplifier (op amp) specifications. This report aims to familiarize the engineer by discussing the basics and modern aspects of VIO by providing a definition and a detailed explaination of causes of VIO for BJT, BiFET, and CMOS devices. Discussion centers around measurement techniques, data sheet specifications, and the effect o
Серия: TLC2654 (14)
TLC2654Q8D, TLC2654Q 8D
