Datasheet Texas Instruments 74ACT16864DL — Даташит
Серия | 74ACT16864 |
Модель | 74ACT16864DL |
18-битные шинные трансиверы с выходами с 3 состояниями 56-SSOP от -40 до 85
18-Bit Bus Transceivers With 3-State Outputs (Rev. A)
PDF, 119 Кб, Версия: A, Файл опубликован: 1 апр 1996
Купить 74ACT16864DL на РадиоЛоцман.Цены — от 335 до 1 013 ₽ 7 предложений от 7 поставщиков Микросхема: BUS TRANSCEIVER | |||
74ACT16864DL Texas Instruments | 335 ₽ | ||
74ACT16864DL Texas Instruments | 343 ₽ | ||
74ACT16864DL Texas Instruments | 403 ₽ | ||
74ACT16864DL Texas Instruments | 1 013 ₽ |
Pin | 56 |
Package Type | DL |
Industry STD Term | SSOP |
JEDEC Code | R-PDSO-G |
Width (мм) | 7.49 |
Length (мм) | 18.41 |
Thickness (мм) | 2.59 |
Pitch (мм) | .635 |
Max Height (мм) | 2.79 |
Mechanical Data | Скачать |
RoHS | Не совместим |
- Selecting the Right Level Translation Solution (Rev. A)PDF, 313 Кб, Версия: A, Файл опубликован: 22 июн 2004
Supply voltages continue to migrate to lower nodes to support today's low-power high-performance applications. While some devices are capable of running at lower supply nodes others might not have this capability. To haveswitching compatibility between these devices the output of each driver must be compliant with the input of the receiver that it is driving. There are several level-translati - Implications of Slow or Floating CMOS Inputs (Rev. D)PDF, 260 Кб, Версия: D, Файл опубликован: 23 июн 2016
- CMOS Power Consumption and CPD Calculation (Rev. B)PDF, 89 Кб, Версия: B, Файл опубликован: 1 июн 1997
Reduction of power consumption makes a device more reliable. The need for devices that consume a minimum amount of power was a major driving force behind the development of CMOS technologies. As a result CMOS devices are best known for low power consumption. However for minimizing the power requirements of a board or a system simply knowing that CMOS devices may use less power than equivale - Designing With Logic (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 1 июн 1997
Data sheets which usually give information on device behavior only under recommended operating conditions may only partially answer engineering questions that arise during the development of systems using logic devices. However information is frequently needed regarding the behavior of the device outside the conditions in the data sheet. Such questions might be:?How does a bus driver behave w - Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Серия: 74ACT16864 (2)
- 74ACT16864DL 74ACT16864DLR
- Semiconductors > Logic > Buffer/Driver/Transceiver > Standard Transceiver
