Datasheet Texas Instruments SN74CBT3125DGVR — Даташит
Серия | SN74CBT3125 |
Модель | SN74CBT3125DGVR |
![Datasheet Texas Instruments SN74CBT3125DGVR](http://www.ti.com/graphics/folders/partimages/SN74CBT3125.jpg)
Четырехместный переключатель шины на полевых транзисторах 14-TVSOP от -40 до 85
SN74CBT3125 datasheet
PDF, 1.4 Мб, Версия: I, Файл опубликован: 19 сен 2002
![]() 18 предложений от 11 поставщиков Микросхема: IC BUS SWITCH 1 X 1:1 14TVSOP | |||
SN74CBT3125DGVR Texas Instruments | 12 ₽ | ||
SN74CBT3125DGVR Texas Instruments | 18 ₽ | ||
SN74CBT3125DGVR Texas Instruments | по запросу | ||
Pin | 14 |
Package Type | DGV |
Industry STD Term | TVSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | CU125 |
Width (мм) | 4.4 |
Length (мм) | 3.6 |
Thickness (мм) | 1.05 |
Pitch (мм) | .4 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Полоса частот | 200 МГц |
Configuration | 1:1 SPST |
Input/Ouput Voltage(Max) | 5.5 В |
Input/Output Continuous Current(Max) | 128 мА |
Input/Output OFF-state Capacitance(Typ) | 4 пФ |
Количество каналов | 4 |
OFF-state leakage current(Max) | 1 мкА |
ON-state leakage current(Max) | 1 мкА |
Package Group | TVSOP |
Package Size: mm2:W x L | 14TVSOP: 23 mm2: 6.4 x 3.6(TVSOP) PKG |
Rating | Catalog |
Ron(Max) | 22 Ohms |
Ron(Typ) | 5 Ohms |
Supply Current(Max) | 3 uA |
Supply Range | 5.5 Max |
VIH(Min) | 2 В |
VIL(Max) | 0.8 В |
Vdd(Max) | 5.5 В |
Vdd(Min) | 4 В |
Vss(Max) | N/A В |
Vss(Min) | N/A В |
- Flexible Voltage-Level Translation With CBT Family DevicesPDF, 40 Кб, Файл опубликован: 20 июл 1999
Voltage translation between buses with incompatible logic levels can be accomplished using Texas Instruments (TI) translation-voltage clamps (TVC) or standard crossbar technology (CBT) devices. CBT devices in this application offer flexibility in designs, protection of circuits that are sensitive to high-state voltage-level overshoots, and cost efficiency. - 5-V To 3.3-V Translation With the SN74CBTD3384 (Rev. B)PDF, 35 Кб, Версия: B, Файл опубликован: 1 мар 1997
The emergence of low-voltage technology required existing 5-V systems to interact with 3.3-V systems. Compatibility issues of mixed-mode operation created the need for 5-V to 3.3-V translation. Buffers and transceivers serve as effective translators. While providing additional drive, these devices also add propagation delay and require directional control. In cases where additional drive is not - 3.3-V to 2.5-V Translation with Texas Instruments Crossbar Technology (Rev. A)PDF, 32 Кб, Версия: A, Файл опубликован: 3 апр 1998
- VOLTAGE LEVEL TRANSLATION (SL) - FamilyPDF, 111 Кб, Файл опубликован: 21 сен 2011
- Bus FET Switch Solutions for Live Insertion ApplicationsPDF, 300 Кб, Файл опубликован: 7 фев 2003
In today?s competitive computing and networking industry, any equipment downtime due to component interconnects or bus failures impedes communication, hinders productivity and hampers financial growth. In recognizing this increasingly costly unplanned downtime, the industry introduced live-insertion technology to minimize the impact of any such failures. The live-insertion feature enables a networ - 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
Серия: SN74CBT3125 (15)
- Semiconductors > Switches and Multiplexers > Analog Switches/Muxes
