Datasheet Texas Instruments SN74LVC16T245ZQLR — Даташит
Серия | SN74LVC16T245 |
Модель | SN74LVC16T245ZQLR |
16-битный трансивер с двойной шиной питания и настраиваемым сдвигом уровня/преобразованием напряжения 56-BGA MICROSTAR JUNIOR от -40 до 85
SN74LVC16T245 16-bit Dual-Supply Bus Transceiver With Configurable Level-Shifting / Voltage Translation and Tri-State Outputs datasheet
PDF, 1.2 Мб, Версия: B, Файл опубликован: 28 апр 2015
Купить SN74LVC16T245ZQLR на РадиоЛоцман.Цены — от 72 до 7 128 ₽ 14 предложений от 11 поставщиков 16Bit Dual-Supply Bus Transceiver with Configurable Level-Shifting / Voltage Translation 56-BGA MICROSTAR JUNIOR -40℃ to 85℃_x0000_` | |||
SN74LVC16T245ZQLR Texas Instruments | 72 ₽ | ||
SN74LVC16T245ZQLR Texas Instruments | 119 ₽ | ||
SN74LVC16T245ZQLR Texas Instruments | 176 ₽ | ||
SN74LVC16T245ZQLR | по запросу |
Pin | 56 |
Package Type | ZQL |
Industry STD Term | BGA MICROSTAR JUNIOR |
JEDEC Code | R-PBGA-N |
Package QTY | 1000 |
Carrier | LARGE T&R |
Маркировка | NK245 |
Width (мм) | 4.5 |
Length (мм) | 7 |
Thickness (мм) | .75 |
Pitch (мм) | .65 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
- LVC Characterization InformationPDF, 114 Кб, Файл опубликован: 1 дек 1996
This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices. - Use of the CMOS Unbuffered Inverter in Oscillator CircuitsPDF, 796 Кб, Файл опубликован: 6 ноя 2003
CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC16T245 (11)
- Semiconductors > Logic > Voltage Level Translation > Direction Controlled Voltage Translation
