Datasheet Texas Instruments OPA345NA/250G4 — Даташит
Серия | OPA345 |
Модель | OPA345NA/250G4 |
Операционные усилители малой мощности с однополярным питанием и Rail-To-Rail MicroAmplifier(TM) Series 5-SOT-23 от -40 до 85
Low Power, Single-Supply, Rail-To-Rail Operational MicroAmplifier™ Series datasheet
PDF, 1.5 Мб, Версия: A, Файл опубликован: 27 авг 2008
Купить OPA345NA/250G4 на РадиоЛоцман.Цены — от 66 до 250 ₽ 13 предложений от 10 поставщиков Low Power, Single-Supply, ail-To- ail Operational Amplifiers MicroAmplifier(TM) Series 5-SOT-23 -40℃ to 85℃ | |||
OPA345NA/250G4 Texas Instruments | 66 ₽ | ||
OPA345NA/250G4 Texas Instruments | 82 ₽ | ||
OPA345NA/250G4 Texas Instruments | 250 ₽ | ||
OPA345NA/250G4 Texas Instruments | по запросу |
Pin | 5 |
Package Type | DBV |
Industry STD Term | SOT-23 |
JEDEC Code | R-PDSO-G |
Width (мм) | 1.6 |
Length (мм) | 2.9 |
Thickness (мм) | 1.2 |
Pitch (мм) | .95 |
Max Height (мм) | 1.45 |
Mechanical Data | Скачать |
Additional Features | Decompensated |
Approx. Price (US$) | 0.50 | 1ku |
Архитектура | CMOS |
CMRR(Min)(dB) | 76 |
CMRR(Typ)(dB) | 92 |
GBW(Typ)(MHz) | 3 |
Input Bias Current(Max)(pA) | 1 |
Iq per channel(Max)(mA) | 0.25 |
Iq per channel(Typ)(mA) | 0.15 |
Number of Channels(#) | 1 |
Offset Drift(Typ)(uV/C) | 3 |
Operating Temperature Range(C) | -40 to 85 |
Output Current(Typ)(mA) | 15 |
Package Group | SOT-23 |
Package Size: mm2:W x L (PKG) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) |
Rail-to-Rail | In Out |
Rating | Catalog |
Slew Rate(Typ)(V/us) | 2 |
Total Supply Voltage(Max)(+5V=5, +/-5V=10) | 5.5 |
Total Supply Voltage(Min)(+5V=5, +/-5V=10) | 2.5 |
Vn at 1kHz(Typ)(nV/rtHz) | 30 |
Vos (Offset Voltage @ 25C)(Max)(mV) | 1 |
RoHS | Не совместим |
- Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA345 (5)
- OPA345NA/250 OPA345NA/250G4 OPA345NA/3K OPA345UA OPA345UAG4
