Datasheet Texas Instruments BQ24087DRCT — Даташит
Серия | BQ24087 |
Модель | BQ24087DRCT |
750 мА ОДНОЧИПОВАЯ ИС ИС УПРАВЛЕНИЯ ЗАРЯДОМ Li-Ion/Li-Pol с терморегулированием 10-VSON от 0 до 125
bq2408x 750-mA Single-Chip Li-Ion and Li-Pol Charge Management IC With Thermal Regulation datasheet
PDF, 1.7 Мб, Версия: E, Файл опубликован: 30 дек 2015
Купить BQ24087DRCT на РадиоЛоцман.Цены — от 85 до 633 ₽ 25 предложений от 14 поставщиков Battery Charge Management 750mA SINGLE-CHIP Li-Ion/Li-Pol CHARGE MANAGEMENT IC with Thermal Regulation Linear Charge Management Li-Ion/Li-Pol Packs 750mA 4.2V 10Pin VSON... | |||
BQ24087DRCT Texas Instruments | 85 ₽ | ||
BQ24087DRCT Texas Instruments | 96 ₽ | ||
BQ24087DRCT Texas Instruments | от 633 ₽ | ||
BQ24087DRCT Texas Instruments | по запросу |
Pin | 10 |
Package Type | DRC |
Industry STD Term | VSON |
JEDEC Code | S-PDSO-N |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | CDX |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | .9 |
Pitch (мм) | .5 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
Absolute Vin (safety rating)(Max)( | 20 В |
Battery Charge Voltage(Max) | 4.2 В |
Battery Charge Voltage(Min) | 4.2 В |
Cell Chemistry | Li-Ion/Li-Polymer |
Charge Current(Max) | 0.75 A |
Control Interface | Standalone (RC-Settable) |
Control Topology | Linear |
Number of Series Cells | 1 |
Operating Vin(Max) | 6.5 В |
Operating Vin(Min) | 4.35 В |
Package Group | VSON |
Package Size: mm2:W x L | 10VSON: 9 mm2: 3 x 3(VSON) PKG |
Special Features | Integrated FET,Temp Monitoring (Thermistor Pin),Thermal Regulation |
USB Feature | N/A |
- Evaluation Modules & Boards: BQ24087EVM
Battery Charger Evaluation Module
- Achieving Different Charge Voltage for bq2408xPDF, 110 Кб, Файл опубликован: 29 апр 2009
By changing standard 4.2-V charge voltage to 4.1 V or lower, rechargeable lithium-ion (Li-ion) battery cycle life can be extended at low temperature. For new chemistry such as LiFePO4 rechargeable battery, it requires 3.6-V charge voltage. All these new applications need a nonstandard charge voltage. This application report gives examples of using the 4.2-V bq24085 charger to achieve different cha - How to Achieve Power-Path Management Function for bq2408x (Rev. A)PDF, 174 Кб, Версия: A, Файл опубликован: 21 апр 2009
This application report presents a simple external circuit for achieving a power-path management function while maintaining an overvoltage protection function and blocking reverse current for low-cost linear battery chargers such as the bq2408x . Brief design criteria and a trade-off study with test results are presented.
Серия: BQ24087 (2)
- BQ24087DRCR BQ24087DRCT
- Semiconductors > Power Management > Battery Management Products > Battery Charger IC
