Datasheet Texas Instruments UCC2809D-2G4 — Даташит
Серия | UCC2809-2 |
Модель | UCC2809D-2G4 |
Экономичный контроллер первичной стороны 8-SOIC от -40 до 85
Economy Primary Side Controller datasheet
PDF, 1.3 Мб, Версия: B, Файл опубликован: 19 ноя 2004
Купить UCC2809D-2G4 на РадиоЛоцман.Цены — от 88 до 28 212 ₽ 10 предложений от 10 поставщиков new in stock for immediate delivery | |||
UCC2809D-2G4 Texas Instruments | 88 ₽ | ||
UCC2809D-2G4 Texas Instruments | 166 ₽ | ||
UCC2809D-2G4 Unitrode | по запросу |
Pin | 8 | 8 |
Package Type | D | D |
Industry STD Term | SOIC | SOIC |
Package QTY | 75 | 75 |
Carrier | TUBE | TUBE |
Маркировка | 2809-2 | D-2 |
Width (мм) | 3.91 | 3.91 |
Length (мм) | 4.9 | 4.9 |
Thickness (мм) | 1.58 | 1.58 |
Pitch (мм) | 1.27 | 1.27 |
Max Height (мм) | 1.75 | 1.75 |
Control Method | Current,Feedforward,Voltage |
Duty Cycle(Max) | 70 % |
Frequency(Max) | 1000 kHz |
Gate Drive(Typ) | 0.8 A |
Package Group | SOIC |
Rating | Catalog |
Special Features | Multi-topology,Soft Start |
Topology | Boost,Flyback,Forward |
UVLO Thresholds On/Off | 15/8 В |
Vin(Max) | 19 В |
Vin(Min) | 8 В |
- Evaluation Modules & Boards: UCC3809EVM
UCC3809 Evaluation Module
- Programming the UCC3809 for 90% Maximum Duty Cycle ClampPDF, 44 Кб, Файл опубликован: 4 июн 2001
Normally, the UCC3809 programmable duty cycle clamp feature is limited to 70% maximum duty cycle. The described technique shows how the maximum duty cycle clamp can be programmed to achieve a 90% on-time of the switching period. - U-168 Implementing a Practical Off-line Lithium-Ion Charger Using the UCC3809PDF, 579 Кб, Файл опубликован: 5 сен 1999
The UCC3809 family of BCDMOS economy low-power integrated circuits contains all the control and drive circuitry required for off-line and isolated DC-to-DC fixed-frequency current-mode switching power supplies with minimal external parts count. The UCC3956 family of Switch-Mode Lithium-Ion Battery Charger Controllers accurately controls lithium-ion battery charging with a highly efficient average - DN-89 Comparing the UC3842, UCC3802, and UCC3809 Primary Side PWM ControllersPDF, 75 Кб, Файл опубликован: 5 сен 1999
Despite the fact that the UC3842 and the UCC3802 PWM Controllers are pin-for-pin compatible, they are not drop-in replacements for each other. Designed as the next generation '42, the UCC3809 also has differences that prevent a simple drop-in substitute. This design note will help the user change from either the UC3842 or the UCC3802 to the UCC3809 in an existing design. A table identifies the mos - U-165 Design Rvw: Isolated 50 W Flyback Converter Using UCC3809 and UC3965PDF, 266 Кб, Файл опубликован: 5 сен 1999
The flyback power stage is a popular choice for single and multiple output DC-to-DC converters at power levels of 150W or less. Without the output inductor required in buck-derived topologies, such as the forward or push-pull converter, the component count and cost are reduced. This application note will re-view the design procedure for the power stage and control electronics of a flyback converte - DN-62 Switching Power Supply Topology Voltage Mode vs. Current ModePDF, 66 Кб, Файл опубликован: 5 сен 1999
This design note explains the differences between voltage-mode and current-mode switching power supply topologies. It includes a circuit diagram for each mode and suggests criteria for choosing which mode to use.
Серия: UCC2809-2 (7)
- UCC2809D-2 UCC2809D-2G4 UCC2809DTR-2 UCC2809DTR-2G4 UCC2809P-2 UCC2809PTR-2 UCC2809PW-2
- Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
UCC2809D2G4, UCC2809D 2G4
