Datasheet Texas Instruments SN74LVC245APWRE4 — Даташит
Серия | SN74LVC245A |
Модель | SN74LVC245APWRE4 |
Восьмеричный шинный трансивер с выходами с 3 состояниями 20-TSSOP от -40 до 125
SN74LVC245A Octal Bus Transceiver With 3-State Outputs datasheet
PDF, 1.6 Мб, Версия: X, Файл опубликован: 25 янв 2015
Купить SN74LVC245APWRE4 на РадиоЛоцман.Цены — от 11 до 88 ₽ 10 предложений от 7 поставщиков Transceiver, Non-Inverting 1 Element 8 Bit per Element 3-State Output 20-TSSOP | |||
SN74LVC245APWRE4 Texas Instruments | 11 ₽ | ||
SN74LVC245APWRE4 Texas Instruments | 13 ₽ | ||
SN74LVC245APWRE4 Texas Instruments | 30 ₽ | ||
SN74LVC245APWRE4 Texas Instruments | по запросу |
Pin | 20 |
Package Type | PW |
Industry STD Term | TSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | LC245A |
Width (мм) | 4.4 |
Length (мм) | 6.5 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Bits | 8 |
F @ Nom Voltage(Max) | 100 Mhz |
ICC @ Nom Voltage(Max) | 0.03 мА |
Output Drive (IOL/IOH)(Max) | -24/24 мА |
Package Group | TSSOP |
Package Size: mm2:W x L | 20TSSOP: 42 mm2: 6.4 x 6.5(TSSOP) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | LVC |
VCC(Max) | 3.6 В |
VCC(Min) | 1.65 В |
Voltage(Nom) | 1.8,2.5,2.7,3.3 В |
tpd @ Nom Voltage(Max) | 12.7,8.3,7.3,6.3 нс |
Серия: SN74LVC245A (29)
- SN74LVC245ADBLE SN74LVC245ADBR SN74LVC245ADBRE4 SN74LVC245ADBRG4 SN74LVC245ADGVR SN74LVC245ADW SN74LVC245ADWG4 SN74LVC245ADWR SN74LVC245ADWRE4 SN74LVC245ADWRG4 SN74LVC245AGQNR SN74LVC245AN SN74LVC245ANE4 SN74LVC245ANSR SN74LVC245ANSRG4 SN74LVC245APW SN74LVC245APWE4 SN74LVC245APWG4 SN74LVC245APWLE SN74LVC245APWR SN74LVC245APWRE4 SN74LVC245APWRG3 SN74LVC245APWRG4 SN74LVC245APWT SN74LVC245APWTE4 SN74LVC245APWTG4 SN74LVC245ARGYR SN74LVC245ARGYRG4 SN74LVC245AZQNR
- Semiconductors > Logic > Buffer/Driver/Transceiver > Standard Transceiver
