Datasheet Texas Instruments TPS61160DRVTG4 — Даташит
Серия | TPS61160 |
Модель | TPS61160DRVTG4 |
Драйвер белого светодиода с цифровой регулировкой яркости и ШИМ в корпусе 2 x 2 мм 6-WSON от -40 до 85
TPS6116x White LED Drivers With Digital and PWM Brightness Control in 2-mm x 2-mm WSON Package datasheet
PDF, 1.7 Мб, Версия: E, Файл опубликован: 14 июл 2016
Купить TPS61160DRVTG4 на РадиоЛоцман.Цены — от 54 до 74 ₽ 14 предложений от 11 поставщиков LED Driver IC 1 Output DC DC Regulator Step-Up (Boost) PWM Dimming 700mA (Switch) 6-WSON (2x2) | |||
TPS61160DRVTG4 Texas Instruments | 54 ₽ | ||
TPS61160DRVTG4 Texas Instruments | 56 ₽ | ||
TPS61160DRVTG4 Texas Instruments | 69 ₽ | ||
TPS61160DRVTG4 Texas Instruments | по запросу |
Pin | 6 |
Package Type | DRV |
Industry STD Term | WSON |
JEDEC Code | S-PDSO-N |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | BZQ |
Width (мм) | 2 |
Length (мм) | 2 |
Thickness (мм) | .75 |
Pitch (мм) | .65 |
Max Height (мм) | .8 |
Mechanical Data | Скачать |
Количество каналов | 1 |
Duty Cycle(Max) | 93 % |
LED | 6 |
LED Current Per Channel | 20 мА |
Package Group | WSON |
Package Size: mm2:W x L | See datasheet (WSON) PKG |
Peak Efficiency | 90 % |
Rating | Catalog |
Shutdown Current(Typ) | 1 uA |
Special Features | EasyScale 1-Wire Interface,Load Disconnect During Shutdown |
Switching Frequency(Max) | 600 kHz |
Topology | Boost |
Тип | Inductive |
Vin(Max) | 18 В |
Vin(Min) | 2.7 В |
Vout(Max) | 26 В |
Vout(Min) | 2.7 В |
- Evaluation Modules & Boards: TPS61160EVM-243
TPS61160EVM-243 Evaluation Module
- TPS6116x With Separate Power Stage and IC Input VoltagesPDF, 194 Кб, Файл опубликован: 2 апр 2009
This application report shows how to operate the TPS6116x integrated circuits (IC) with two separate input power rails, one for the boost power stage and one to power the IC itself. In this example, an input as low as 1.8 V from discharged dual-alkaline batteries supplies power to the boost stage, whereas a separate 3.3-V supply powers the IC. - How to Use Analog Dimming With TPS6116xPDF, 162 Кб, Файл опубликован: 5 авг 2011
The TPS6116x family of devices are simple, white LED drivers that can drive up to 10 LEDs in series. The CTRL pin on these devices is the input for the integrated analog dimming circuitry but can only be used for PWM signals switching higher than 5 kHz. This application report shows a simple, external circuit that can be used to perform analog dimming from PWM signals that are below 5 kHz as well - Extending the Input Voltage Range of the TPS6116x/8x/9x WLED DriversPDF, 124 Кб, Файл опубликован: 12 авг 2009
The TPS6116x, TPS6118x and TPS6119x WLED driver and TPS6117x boost converter integrated circuits (IC) can operate with different input voltages, one powering the IC itself and the other powering the boost power stage. This application report explains various options on how to use the WLED drivers with split power rails. This allows these LED drivers to be used in applications where the available - Analog PWM Dimming in White-LED DriversPDF, 539 Кб, Файл опубликован: 21 дек 2016
Pulse-width modulation (PWM) is a common type of dimming used to adjust the current in white-LEDdriver devices. PWM dimming takes a rectangle waveform with variable positive duty cycle (D) and adjuststhe LED current proportionally. For many smaller format white LED drivers (7-inch screen size or smaller),the PWM signal is converted to a DC control voltage and made to drive the LED current in - Schottky Diode Selection in Asynchronous Boost ConvertersPDF, 491 Кб, Файл опубликован: 6 сен 2016
Asynchronous boost converters require a Schottky diode as the rectifying element due to the diode's lowforward voltage and fast turn-on time. Because of these characteristics asynchronous boost converterscan have as good as, or better efficiency, than synchronous boost converters. This is especially true whenthe boost conversion ratios (VOUT/VIN) are high, and the Schottky diode conduction t - Inductor Selection in Boost Converters for LCD Backlight ApplicationsPDF, 764 Кб, Файл опубликован: 24 окт 2016
White LED drivers for LCD back-light applications are often designed for battery-powered devices. This makes circuit size and efficiency crucial. Because of this, selecting the optimal inductor is one of the mostimportant aspects of the design. This application note discusses the important parameters of the inductorand how to select the right inductor for the application. - Optimizing Transient Response of Internally Compensated DC-DC Converters (Rev. A)PDF, 1.1 Мб, Версия: A, Файл опубликован: 11 май 2015
- Extending the Soft Start Time Without a Soft Start Pin (Rev. B)PDF, 387 Кб, Версия: B, Файл опубликован: 15 июн 2017
- Performing Accurate PFM Mode Efficiency Measurements (Rev. A)PDF, 418 Кб, Версия: A, Файл опубликован: 11 дек 2018
Серия: TPS61160 (4)
- TPS61160DRVR TPS61160DRVRG4 TPS61160DRVT TPS61160DRVTG4
- Semiconductors > Power Management > LED Driver > Backlight LED Driver
