Datasheet Texas Instruments ISO7820DWR — Даташит
Серия | ISO7820 |
Модель | ISO7820DWR |
Усиленный двухканальный цифровой изолятор 2/0 с высокой устойчивостью, 5,7 кВэфф., 16-SOIC, 100 Мбит/с, от -55 до 125
ISO7820x High-Performance, 8000 VPK Reinforced Dual Channel Digital Isolator datasheet
PDF, 1.4 Мб, Версия: A, Файл опубликован: 24 мар 2016
Купить ISO7820DWR на РадиоЛоцман.Цены — от 266 до 338 ₽ 9 предложений от 6 поставщиков Digital Isolator CMOS 2CH 100Mbps Automotive Medical 16Pin SOIC T/R | |||
ISO7820DWR Texas Instruments | 266 ₽ | ||
ISO7820DWR Texas Instruments | 280 ₽ | ||
ISO7820DWR Texas Instruments | 286 ₽ | ||
ISO7820DWR Texas Instruments | по запросу |
Pin | 16 |
Package Type | DW |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | ISO7820 |
Width (мм) | 7.5 |
Length (мм) | 10.3 |
Thickness (мм) | 2.35 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2.65 |
Mechanical Data | Скачать |
Data Rate(Max) | 100 Mbps |
Default Output | High |
Forward/Reverse Channels | 2/0 |
Integrated Isolated Power | No |
Isolation Rating | 5700 Vrms |
Количество каналов | 2 |
Package Group | SOIC |
Package Size: mm2:W x L | 16SOIC: 106 mm2: 10.3 x 10.3(SOIC) PKG |
Время задержки распространения | 10.7 нс |
Propagation Delay(Typ) | 10.7 нс |
Rating | Catalog |
Surge Voltage Rating | 8000 Vpk |
VCC(Max) | 5.5 В |
VCC(Min) | 2.25 В |
- Evaluation Modules & Boards: ISO7842-EVM
High-Immunity, 5.7kVRMS Reinforced Quad-Channel 2/2 Digital Isolator Evaluation Module
- Shelf-Life Evaluation of Lead-Free Component FinishesPDF, 1.3 Мб, Файл опубликован: 24 май 2004
The integrated circuit (IC) industry is converting to lead (Pb)-free termination finishes for leadframe-based packages. IC component users need to know the maximum length of time that components can be stored prior to being soldered. This study predicts shelf life of the primary Pb-free finishes being proposed by the industry. Components were exposed to a controlled environment, with known aging a - Isolation GlossaryPDF, 52 Кб, Файл опубликован: 27 окт 2014
- Digital Isolator Design Guide (Rev. A)PDF, 487 Кб, Версия: A, Файл опубликован: 4 ноя 2014
Серия: ISO7820 (8)
- Semiconductors > Isolation > Digital Isolators
