Datasheet Texas Instruments UCC383TDTR-3G3 — Даташит
Серия | UCC383 |
Модель | UCC383TDTR-3G3 |
Линейные регуляторы 3-А с низким падением напряжения 3-DDPAK/TO-263 от 0 до 70
UCC283-x, UCC383-x: Low-Dropout 3-A Linear Regulator Family datasheet
PDF, 1.1 Мб, Версия: B, Файл опубликован: 23 фев 2004
Купить UCC383TDTR-3G3 на РадиоЛоцман.Цены — от 210 до 360 ₽ 12 предложений от 9 поставщиков Low-Dropout, 3-A, Linear Regulators 3-DDPAK/TO-263 0 to 70 | |||
UCC383TDTR-3G3 Texas Instruments | от 210 ₽ | ||
UCC383TDTR-3G3 Texas Instruments | 224 ₽ | ||
UCC383TDTR-3G3 Texas Instruments | по запросу | ||
Pin | 3 |
Package Type | KTT |
Industry STD Term | TO-263 |
JEDEC Code | R-PSFM-G |
Package QTY | 500 |
Carrier | LARGE T&R |
Маркировка | UCC383TD-3 |
Width (мм) | 8.41 |
Length (мм) | 10.18 |
Thickness (мм) | 4.44 |
Pitch (мм) | 2.54 |
Max Height (мм) | 4.83 |
Mechanical Data | Скачать |
Точность | 2.5 % |
Fixed Output Options | 3.3,5 В |
Iout(Max) | 3 A |
Iq(Typ) | 0.4 мА |
Рабочий диапазон температур | от 0 до 70 C |
Output Capacitor Type | Non-Ceramic |
Output Options | Adjustable Output,Fixed Output |
PSRR @ 100KHz | 18 дБ |
Package Group | DDPAK/TO-263 |
Package Size: mm2:W x L | 3DDPAK/TO-263: 155 mm2: 15.24 x 10.16(DDPAK/TO-263) PKG |
Rating | Catalog |
Regulated Outputs | 1 |
Special Features | Reverse Current Protection |
Vdo(Typ) | 400 мВ |
Vin(Max) | 9 В |
Vin(Min) | 2.8 В |
Vout(Max) | 8.5 В |
Vout(Min) | 1.2 В |
- Using LDOs and Power Managers in Systems with Redundant Power SuppliesPDF, 58 Кб, Файл опубликован: 29 ноя 2000
For reasons of continuity in some systems, independent power sources must operate in parallel. The traditional way to connect two ore more power sources in parallel uses isolation diodes. However, in situations where the associated voltage drop or the presence of voltage-feedback sensing wires makes using isolation diodes undesirable, special types of low dropout voltage regulators (LDOs) and hot- - High Current LDO Linear Reglators (UCCx81-ADJ, UCx82-ADJ, UCCx83-ADJ, UCx85-ADPDF, 56 Кб, Файл опубликован: 7 май 2002
This application provides an overview of the UCCx81-ADJ, UCCx82-ADJ, UCCx83-ADJ, UCCx84-ADJ, and UCcx85-ADJ devices.
Серия: UCC383 (18)
UCC383TDTR3G3, UCC383TDTR 3G3
