Datasheet Texas Instruments M38510/37701B2A — Даташит
Серия | SN54ALS138A |
Модель | M38510/37701B2A |
Декодеры/демультиплексоры с 3-8 строками 20-LCCC от -55 до 125
3-Line To 8-Line Decoders/Demultiplexers datasheet
PDF, 1.1 Мб, Версия: E, Файл опубликован: 1 июл 1996
M38510/37701B2A Texas Instruments | 2 517 ₽ |
Pin | 20 | 20 |
Package Type | FK | FK |
Industry STD Term | LCCC | LCCC |
JEDEC Code | S-CQCC-N | S-CQCC-N |
Package QTY | 1 | 1 |
Carrier | TUBE | TUBE |
Маркировка | 37701B2A | JM38510/ |
Width (мм) | 8.89 | 8.89 |
Length (мм) | 8.89 | 8.89 |
Thickness (мм) | 1.83 | 1.83 |
Pitch (мм) | 1.27 | 1.27 |
Max Height (мм) | 2.03 | 2.03 |
Количество каналов | 1 |
F @ Nom Voltage(Max) | 75 Mhz |
ICC @ Nom Voltage(Max) | 10 мА |
Package Group | LCCC |
Package Size: mm2:W x L | 20LCCC: 79 mm2: 8.89 x 8.89(LCCC) PKG |
Rating | Military |
Schmitt Trigger | No |
Technology Family | ALS |
VCC(Max) | 5.5 В |
VCC(Min) | 4.5 В |
Voltage(Nom) | 5 В |
tpd @ Nom Voltage(Max) | 22 нс |
RoHS | See ti.com |
- Advanced Schottky (ALS and AS) Logic FamiliesPDF, 1.9 Мб, Файл опубликован: 1 авг 1995
This document introduces the advanced Schottky family of clamped TTL integrated circuits (ICs). Detailed electrical characteristics of the 'AS and 'ALS devices with table formats are provided. Guidelines for designing high-performance digital systems using the Advanced Schottky family are given along with a brief summary of the solutions to most design decisions needed to implement systems using t - Bus-Interface Devices With Output-Damping Resistors Or Reduced-Drive Outputs (Rev. A)PDF, 105 Кб, Версия: A, Файл опубликован: 1 авг 1997
Серия: SN54ALS138A (10)
- Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Decoders/Encoders/Multiplexers
