Datasheet Texas Instruments SN74LVC1G19DCKRE4 — Даташит
Серия | SN74LVC1G19 |
Модель | SN74LVC1G19DCKRE4 |
Декодер/демультиплексор 1 из 2 6-SC70 от -40 до 85
SN74LVC1G19 1-of-2 Decoder and Demultiplexer datasheet
PDF, 1.3 Мб, Версия: G, Файл опубликован: 31 авг 2015
Купить SN74LVC1G19DCKRE4 на РадиоЛоцман.Цены — от 6.71 до 9.63 ₽ 9 предложений от 9 поставщиков Decoder/Demultiplexer 1 x 1:2 SC-70-6 | |||
SN74LVC1G19DCKRE4 Texas Instruments | 6.71 ₽ | ||
SN74LVC1G19DCKRE4 Texas Instruments | 7.81 ₽ | ||
SN74LVC1G19DCKRE4 Texas Instruments | 9.63 ₽ | ||
SN74LVC1G19DCKRE4 Texas Instruments | по запросу |
Pin | 6 | 6 | 6 | 6 |
Package Type | DCK | DCK | DCK | DCK |
Industry STD Term | SOT-SC70 | SOT-SC70 | SOT-SC70 | SOT-SC70 |
JEDEC Code | R-PDSO-G | R-PDSO-G | R-PDSO-G | R-PDSO-G |
Package QTY | 3000 | 3000 | 3000 | 3000 |
Carrier | LARGE T&R | LARGE T&R | LARGE T&R | LARGE T&R |
Маркировка | CYK | CY5 | CYR | CYF |
Width (мм) | 1.25 | 1.25 | 1.25 | 1.25 |
Length (мм) | 2 | 2 | 2 | 2 |
Thickness (мм) | .9 | .9 | .9 | .9 |
Pitch (мм) | .65 | .65 | .65 | .65 |
Max Height (мм) | 1.1 | 1.1 | 1.1 | 1.1 |
Mechanical Data | Скачать | Скачать | Скачать | Скачать |
3-State Output | No |
Bits | 1 |
F @ Nom Voltage(Max) | 150 Mhz |
Gate Type | DECODER/DEMUX |
ICC @ Nom Voltage(Max) | 0.01 мА |
Logic | True |
Output Drive (IOL/IOH)(Max) | 32/-32 мА |
Package Group | SC70 |
Package Size: mm2:W x L | 6SC70: 4 mm2: 2.1 x 2(SC70) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Special Features | Ioff,down translation to Vcc,low power |
Sub-Family | Decoder/Encoder/Multiplexer |
Technology Family | LVC |
VCC(Max) | 5.5 В |
VCC(Min) | 1.65 В |
Voltage(Nom) | 1.8,2.5,3.3,5 В |
tpd @ Nom Voltage(Max) | 16.1,6.5,5.2,3.9 нс |
- LVC Characterization InformationPDF, 114 Кб, Файл опубликован: 1 дек 1996
This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices. - Use of the CMOS Unbuffered Inverter in Oscillator CircuitsPDF, 796 Кб, Файл опубликован: 6 ноя 2003
CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC1G19 (11)
- Semiconductors > Logic > Little Logic
