Datasheet Texas Instruments SMJ320C25-50FJM — Даташит
Серия | SMJ320C25 |
Модель | SMJ320C25-50FJM |
Процессоры цифровых сигналов 68-JLCC от -55 до 125
SMJ320C25, SMJ320C25-50 Digital Signal Processors datasheet
PDF, 738 Кб, Версия: D, Файл опубликован: 31 окт 2001
6 предложений от 6 поставщиков MILITARY GRADE C25 FLOATING-POIN | |||
SMJ320C25-50FJM Texas Instruments | 65 672 ₽ | ||
SMJ320C25-50FJM | по запросу | ||
SMJ320C25-50FJM Texas Instruments | по запросу |
Pin | 68 | 68 | 68 | 68 | 68 | 68 |
Package Type | FJ | FJ | FJ | FJ | FJ | FJ |
Industry STD Term | JLCC | JLCC | JLCC | JLCC | JLCC | JLCC |
JEDEC Code | S-CQCC-J | S-CQCC-J | S-CQCC-J | S-CQCC-J | S-CQCC-J | S-CQCC-J |
Package QTY | 1 | 1 | 1 | 1 | 1 | 1 |
Carrier | JEDEC TRAY (10+1) | JEDEC TRAY (10+1) | JEDEC TRAY (10+1) | JEDEC TRAY (10+1) | JEDEC TRAY (10+1) | JEDEC TRAY (10+1) |
Маркировка | 5962-8861902ZA | SMJ320C25-50FJ | M | SMJ320C25-50FJ | M | 5962-8861902ZA |
Width (мм) | 24.2 | 24.2 | 24.2 | 24.2 | 24.2 | 24.2 |
Length (мм) | 24.2 | 24.2 | 24.2 | 24.2 | 24.2 | 24.2 |
Thickness (мм) | 2.16 | 2.16 | 2.16 | 2.16 | 2.16 | 2.16 |
Pitch (мм) | 1.27 | 1.27 | 1.27 | 1.27 | 1.27 | 1.27 |
Max Height (мм) | 3.68 | 3.68 | 3.68 | 3.68 | 3.68 | 3.68 |
Mechanical Data | Скачать | Скачать | Скачать | Скачать | Скачать | Скачать |
Cycle Time | 100 нс |
DMA | Ext Ch |
Data / Program Memory Space | 64K/64K Words |
Тактовая частота | 40 МГц |
MIPS | 10 |
MOPS | 60 |
Package Group | JLCC |
Pin/Package | 68CPGA, 68JLCC, 68LCCC |
Rating | Military |
RoHS | See ti.com |
- Engine Knock Detection Using Spectral Analysis With TMS320C25 or TMS320C30 DSPsPDF, 254 Кб, Файл опубликован: 1 янв 1995
An efficient method of detecting combustion engine knock is using spectral analysis. The detection process algorithm adapts to a no-knock reference at varying speeds and loads by using multiple frequencies. This document presents an problem overview current technology and two implementation examples are given to aid in the development of system specific hardware and software. The first system is - Setting Up TMS320 DSP Interrupts in 'C'PDF, 168 Кб, Файл опубликован: 1 ноя 1994
Four steps are required to set the TMS320 DSP interrupts: create a interrupt service routine initialize the vector table and set the memory map enable the interrupts in the CPU and enable the interrupt sources. This document shows how to set the interrupts in C C callable assembly or in-line C. Sample C code segments are provided. The appendix gives complete examples for setting interrupt vec - Minimizing Quantization Effects Using the TMS320 DSP FamilyPDF, 268 Кб, Файл опубликован: 1 июл 1994
Due to its discrete nature DSPs represent variables and performs arithmetic functions with a finite word length. This produces three effects: the selection of filter transfer functions is quantized with filter poles and zeros existing only at specific locations in the z plane; the input is quantized; and noise is introduced from DSP multiplication and division operations. This document shows how
Серия: SMJ320C25 (11)
- Semiconductors > Processors > Digital Signal Processors > Other High Reliability DSPs
SMJ320C2550FJM, SMJ320C25 50FJM
