Datasheet Texas Instruments SN74LVCH244APWT — Даташит
Серия | SN74LVCH244A |
Модель | SN74LVCH244APWT |
Восьмеричный буфер/драйвер с выходами с 3 состояниями 20-TSSOP от -40 до 85
SN54LVCH244A, SN74LVCH244A datasheet
PDF, 1.6 Мб, Версия: O, Файл опубликован: 5 фев 2007
Купить SN74LVCH244APWT на РадиоЛоцман.Цены — от 22 до 106 ₽ 19 предложений от 12 поставщиков Buffer/Line Driver 8CH Non-Inverting 3-ST CMOS 20Pin TSSOP T/R | |||
SN74LVCH244APWT Texas Instruments | 22 ₽ | ||
SN74LVCH244APWTE4 Texas Instruments | 29 ₽ | ||
SN74LVCH244APWT Texas Instruments | 42 ₽ | ||
SN74LVCH244APWT Texas Instruments | 43 ₽ |
Pin | 20 |
Package Type | PW |
Industry STD Term | TSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | LCH244A |
Width (мм) | 4.4 |
Length (мм) | 6.5 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Bits | 8 |
F @ Nom Voltage(Max) | 100 Mhz |
ICC @ Nom Voltage(Max) | 0.01 мА |
Output Drive (IOL/IOH)(Max) | -24/24 мА |
Package Group | TSSOP |
Package Size: mm2:W x L | 20TSSOP: 42 mm2: 6.4 x 6.5(TSSOP) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | LVC |
VCC(Max) | 3.6 В |
VCC(Min) | 1.65 В |
Voltage(Nom) | 1.8,2.5,2.7,3.3 В |
tpd @ Nom Voltage(Max) | 6.9,5.9 нс |
- Bus-Hold CircuitPDF, 418 Кб, Файл опубликован: 5 фев 2001
When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of
Серия: SN74LVCH244A (19)
- SN74LVCH244ADBLE SN74LVCH244ADBQR SN74LVCH244ADBQRE4 SN74LVCH244ADBR SN74LVCH244ADGVR SN74LVCH244ADW SN74LVCH244ADWG4 SN74LVCH244ADWR SN74LVCH244ANSR SN74LVCH244ANSRG4 SN74LVCH244APW SN74LVCH244APWLE SN74LVCH244APWR SN74LVCH244APWRE4 SN74LVCH244APWRG4 SN74LVCH244APWT SN74LVCH244APWTE4 SN74LVCH244ARGYR SN74LVCH244ARGYRG4
- Semiconductors > Logic > Buffer/Driver/Transceiver > Non-Inverting Buffer/Driver
