Datasheet Texas Instruments CD54HC243F — Даташит
Серия | CD54HC243 |
Модель | CD54HC243F |
Высокоскоростной КМОП-логический трансивер с четырьмя шинами и выходами с 3 состояниями, 14-CDIP, от -55 до 125
CD54HC243, CD74HC243, CD54HCT243, CD74HCT243 datasheet
PDF, 716 Кб, Версия: D, Файл опубликован: 21 окт 2003
Купить CD54HC243F на РадиоЛоцман.Цены — от 1 290 до 4 964 ₽ 15 предложений от 12 поставщиков High-Speed CMOS Logic Quad-Bus Transceiver with Three-State Outputs | |||
CD54HC243F Texas Instruments | 1 290 ₽ | ||
CD54HC243F Texas Instruments | 1 886 ₽ | ||
CD54HC243F Texas Instruments | по запросу | ||
CD54HC243F3A Harris | по запросу |
Pin | 14 |
Package Type | J |
Industry STD Term | CDIP |
JEDEC Code | R-GDIP-T |
Package QTY | 1 |
Carrier | TUBE |
Маркировка | CD54HC243F |
Width (мм) | 6.67 |
Length (мм) | 19.56 |
Thickness (мм) | 4.57 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
Bits | 4 |
Package Group | CDIP |
Package Size: mm2:W x L | See datasheet (CDIP) PKG |
Rating | Military |
Schmitt Trigger | No |
Technology Family | HC |
VCC(Max) | 6 В |
VCC(Min) | 2 В |
RoHS | See ti.com |
- CMOS Power Consumption and CPD Calculation (Rev. B)PDF, 89 Кб, Версия: B, Файл опубликован: 1 июн 1997
Reduction of power consumption makes a device more reliable. The need for devices that consume a minimum amount of power was a major driving force behind the development of CMOS technologies. As a result CMOS devices are best known for low power consumption. However for minimizing the power requirements of a board or a system simply knowing that CMOS devices may use less power than equivale - Selecting the Right Texas Instruments Signal SwitchPDF, 769 Кб, Файл опубликован: 7 сен 2001
Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi - Designing With Logic (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 1 июн 1997
Data sheets which usually give information on device behavior only under recommended operating conditions may only partially answer engineering questions that arise during the development of systems using logic devices. However information is frequently needed regarding the behavior of the device outside the conditions in the data sheet. Such questions might be:?How does a bus driver behave w - Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Though low power consumption is a feature of CMOS devices sometimes this feature does not meet a designer?s system power supply constraints. Therefore a partial system power down or multiple Vcc supplies are used to meet the needs of the system. This document shows electrostatic discharge protection circuits. It also provides circuit and bus driver examples of partial system power down and curren - SN54/74HCT CMOS Logic Family Applications and RestrictionsPDF, 102 Кб, Файл опубликован: 1 май 1996
Серия: CD54HC243 (3)
- 8409001CA CD54HC243F CD54HC243F3A
- Semiconductors > Space & High Reliability > Logic Products > Buffers/Drivers/Transceivers > Transceivers
