Datasheet Texas Instruments OPA564AIDWPR — Даташит
Серия | OPA564 |
Модель | OPA564AIDWPR |
1,5 А, 24 В, 17 МГц, операционный усилитель мощности 20-SO PowerPAD от -40 до 85
1.5A, 24V, 17MHz Power Operational Amplifier datasheet
PDF, 1.7 Мб, Версия: E, Файл опубликован: 28 янв 2011
Купить OPA564AIDWPR на РадиоЛоцман.Цены — от 191 до 1 359 ₽ 24 предложений от 13 поставщиков 1.5A, 24V, 17MHz, Power Operational Amplifier 20-SO PowerPAD -40℃ to 85℃ | |||
OPA564AIDWPR Texas Instruments | 191 ₽ | ||
OPA564AIDWPR Texas Instruments | 223 ₽ | ||
OPA564AIDWPR Texas Instruments | 1 264 ₽ | ||
OPA564AIDWPR Texas Instruments | 1 330 ₽ |
Pin | 20 |
Package Type | DWP |
Industry STD Term | HSOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | OPA564 |
Width (мм) | 7.52 |
Length (мм) | 12.82 |
Thickness (мм) | 2.55 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2.65 |
Mechanical Data | Скачать |
Additional Features | Adj Current Limit,Shutdown |
Архитектура | FET |
CMRR(Min) | 70 дБ |
CMRR(Typ) | 90 дБ |
GBW(Typ) | 17 МГц |
Input Bias Current(Max) | 100 pA |
Iq per channel(Max) | 50 мА |
Iq per channel(Typ) | 39 мА |
Количество каналов | 1 |
Offset Drift(Typ) | 10 uV/C |
Output Current(Typ) | 1500 мА |
Package Group | SO PowerPAD |
Package Size: mm2:W x L | 20SO PowerPAD: 133 mm2: 10.405 x 12.825(SO PowerPAD) PKG |
Rail-to-Rail | In to V- |
Rating | Catalog |
Slew Rate(Typ) | 40 V/us |
Total Supply Voltage(Max) | 24 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 7 +5V=5, +/-5V=10 |
Vos (Offset Voltage @ 25C)(Max) | 20 мВ |
- Biasing Considerations for OPA564 During Enabled and Disabled StatesPDF, 130 Кб, Файл опубликован: 6 мар 2011
The OPA564 is a high-voltage, high-current, wide-bandwidth operational amplifier suitable for many applications. Among the many features available on the OPA564 is a disabled mode that is designed to be used for power savings in time multiplexed systems such as powerline communications. When using an op amp that can be placed into either the enabled state or disabled state (shutdown), it is critic - Power Amplifier Stress and Power Handling LimitationsPDF, 55 Кб, Файл опубликован: 27 сен 2000
To achieve reliable power amplifier designs you must consider the stress on the amplifier compared to its power handling limitations. Power handling limits are specified by the Safe Operating Area (SOA) curves of the power amp. Stress on the amplifier depends on amplifier load and signal conditions which can be evaluated with straightforward techniques.
Серия: OPA564 (4)
- OPA564AIDWD OPA564AIDWDR OPA564AIDWP OPA564AIDWPR
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > Power Op Amps
