Datasheet Texas Instruments 85511012A — Даташит
Серия | SN54F245 |
Модель | 85511012A |
![Datasheet Texas Instruments 85511012A](http://www.ti.com/graphics/folders/partimages/SN54F245.jpg)
Восьмеричные шинные трансиверы с выходами с 3 состояниями 20-LCCC от -55 до 125
Octal Bus Transceivers With 3-State Outputs datasheet
PDF, 1.3 Мб, Версия: A, Файл опубликован: 1 окт 1993
Купить 85511012A на РадиоЛоцман.Цены — от 1 310 до 1 324 ₽ 5 предложений от 5 поставщиков OCTAL BUS TRANSCEIVERS WITH 3-STATE OUTPUTS | |||
85511012A Texas Instruments | 1 310 ₽ | ||
85511012A Texas Instruments | 1 324 ₽ | ||
85511012A Texas Instruments | по запросу | ||
85511012A/883 Texas Instruments | по запросу |
Pin | 20 | 20 | 20 |
Package Type | FK | FK | FK |
Industry STD Term | LCCC | LCCC | LCCC |
JEDEC Code | S-CQCC-N | S-CQCC-N | S-CQCC-N |
Package QTY | 1 | 1 | 1 |
Carrier | TUBE | TUBE | TUBE |
Маркировка | SNJ54F | 85511012A | 245FK |
Width (мм) | 8.89 | 8.89 | 8.89 |
Length (мм) | 8.89 | 8.89 | 8.89 |
Thickness (мм) | 1.83 | 1.83 | 1.83 |
Pitch (мм) | 1.27 | 1.27 | 1.27 |
Max Height (мм) | 2.03 | 2.03 | 2.03 |
Bits | 8 |
Package Group | LCCC |
Package Size: mm2:W x L | 20LCCC: 79 mm2: 8.89 x 8.89(LCCC) PKG |
Rating | Military |
Schmitt Trigger | No |
Technology Family | F |
VCC(Max) | 5.5 В |
VCC(Min) | 4.5 В |
RoHS | See ti.com |
- Bus-Interface Devices With Output-Damping Resistors Or Reduced-Drive Outputs (Rev. A)PDF, 105 Кб, Версия: A, Файл опубликован: 1 авг 1997
The spectrum of bus-interface devices with damping resistors or balanced/light output drive currently offered by various logic vendors is confusing at best. Inconsistencies in naming conventions and methods used for implementation make it difficult to identify the best solution for a given application. This report attempts to clarify the issue by looking at several vendors? approaches and discussi - Input and Output Characteristics of Digital Integrated CircuitsPDF, 1.7 Мб, Файл опубликован: 1 окт 1996
This report contains a comprehensive collection of the input and output characteristic curves of typical integrated circuits from various logic families. These curves go beyond the information given in data sheets by providing additional details regarding the characteristics of the components. This knowledge is particularly useful when for example a decision must be made as to which circuit shou - Designing With Logic (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 1 июн 1997
Серия: SN54F245 (13)
- Semiconductors > Space & High Reliability > Logic Products > Buffers/Drivers/Transceivers > Transceivers
