Datasheet Texas Instruments 7601001FA — Даташит
Серия | SN54LS151 |
Модель | 7601001FA |
Селекторы данных/мультиплексоры 16-CFP от -55 до 125
Data Selectors/Multiplexers datasheet
PDF, 1.1 Мб, Файл опубликован: 1 мар 1988
Купить 7601001FA на РадиоЛоцман.Цены — от 751 до 2 245 ₽ 7 предложений от 7 поставщиков Микросхема: MULTIPLEXER, LS SERIES TTL | |||
7601001FA Texas Instruments | 751 ₽ | ||
7601001FA Texas Instruments | 768 ₽ | ||
7601001FA Texas Instruments | 926 ₽ | ||
7601001FA Texas Instruments | по запросу |
Pin | 16 | 16 |
Package Type | W | W |
Industry STD Term | CFP | CFP |
JEDEC Code | R-GDFP-F | R-GDFP-F |
Carrier | TUBE | TUBE |
Маркировка | SNJ54LS151W | 7601001FA |
Width (мм) | 6.73 | 6.73 |
Length (мм) | 10.3 | 10.3 |
Thickness (мм) | 1.65 | 1.65 |
Pitch (мм) | 1.27 | 1.27 |
Max Height (мм) | 2.03 | 2.03 |
Channels(#) | 1 |
F @ Nom Voltage(Max)(Mhz) | 35 |
Operating Temperature Range(C) | -55 to 125 |
Package Group | CFP |
Package Size: mm2:W x L (PKG) | See datasheet (CFP) |
Rating | Military |
Schmitt Trigger | No |
Technology Family | LS |
VCC(Max)(V) | 5.5 |
VCC(Min)(V) | 4.5 |
Voltage(Nom)(V) | 5 |
RoHS | Не совместим |
- Input and Output Characteristics of Digital Integrated CircuitsPDF, 1.7 Мб, Файл опубликован: 1 окт 1996
This report contains a comprehensive collection of the input and output characteristic curves of typical integrated circuits from various logic families. These curves go beyond the information given in data sheets by providing additional details regarding the characteristics of the components. This knowledge is particularly useful when for example a decision must be made as to which circuit shou - Designing With Logic (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 1 июн 1997
Data sheets which usually give information on device behavior only under recommended operating conditions may only partially answer engineering questions that arise during the development of systems using logic devices. However information is frequently needed regarding the behavior of the device outside the conditions in the data sheet. Such questions might be:?How does a bus driver behave w - Designing with the SN54/74LS123 (Rev. A)PDF, 118 Кб, Версия: A, Файл опубликован: 1 мар 1997
Серия: SN54LS151 (13)
- Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Decoders/Encoders/Multiplexers
