Datasheet Texas Instruments SN65LBC182DG4 — Даташит
Серия | SN65LBC182 |
Модель | SN65LBC182DG4 |
Полудуплекс, ESD 15 кВ, приемопередатчик 1/4 UL 8-SOIC от -40 до 85
SN65LBC182, SN75LBC182 Differential Bus Transceiver datasheet
PDF, 877 Кб, Версия: A, Файл опубликован: 25 мар 2005
Купить SN65LBC182DG4 на РадиоЛоцман.Цены — от 158 до 293 ₽ 9 предложений от 9 поставщиков Half-duplex, 15kV ESD, 1/4 UL Transceiver 8-SOIC -40℃ to 85℃ | |||
SN65LBC182DG4 Texas Instruments | 158 ₽ | ||
SN65LBC182DG4 Texas Instruments | 171 ₽ | ||
SN65LBC182DG4 Texas Instruments | по запросу | ||
SN65LBC182DG4 | по запросу |
Pin | 8 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 75 |
Carrier | TUBE |
Маркировка | 6LB182 |
Width (мм) | 3.91 |
Length (мм) | 4.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Common Mode Range | -7 to 12 |
Duplex | Half |
Fail Safe | Open |
Fault Protection | -10 to 15 В |
HBM ESD | 15 kV |
ICC(Max) | 30 мА |
IEC 61000-4-2 Contact | 8 +/- kV |
Isolated | No |
No. of RX | 1 |
No. of TX | 1 |
Number of Nodes | 128 |
Package Group | SOIC |
Rating | Catalog |
Signaling Rate(Max) | 0.25 Mbps |
Supply Voltage(s)(Nom) | 5 В |
- Evaluation Modules & Boards: RS485-HF-DPLX-EVM
RS-485 Half-Duplex Evaluation Module
- RS-485 for E-Meter Applications (Rev. A)PDF, 311 Кб, Версия: A, Файл опубликован: 6 авг 2004
This application report discusses the best practices for designing energy meter communication circuits using the RS-485 standard. Component selection and performance tradeoffs are covered with reference to relevant standards such as IEC 61036 and DL/T 645. Reference design details are provided to help energy meter engineers successfully complete their own circuit designs. - The RS-485 Unit Load and Maximum Number of Bus ConnectionsPDF, 197 Кб, Файл опубликован: 15 мар 2004
The TIA/EIA-485 (RS-485) standard defines a Unit Load and confines bus configurations to 32. This report explains the Unit-Load concept and how it relates to the maximum number of bus connections. Fractional Unit-Load devices, such at the 1/8th Unit-Load SN65HVD21 and SN65HVD06, allow up to 256 devices on a single bus segment.
Серия: SN65LBC182 (6)
- SN65LBC182D SN65LBC182DG4 SN65LBC182DR SN65LBC182DRG4 SN65LBC182P SN65LBC182PE4
- Semiconductors > Interface > RS-485/RS-422
