Datasheet Texas Instruments REF3140AIDBZTG4 — Даташит
Серия | REF3140 |
Модель | REF3140AIDBZTG4 |
20ppm/В°C Max, 100ВµA, SOT23-3 Series Voltage Reference 3-SOT-23 -40 to 125
REF31xx 15ppm/В°C Maximum, 100-µA, SOT-23 Series Voltage Reference datasheet
PDF, 1.3 Мб, Версия: D, Файл опубликован: 31 мар 2016
Купить REF3140AIDBZTG4 на РадиоЛоцман.Цены — от 93 до 273 ₽ 14 предложений от 11 поставщиков 20ppm/Degrees C Max, 100uA, SOT23-3 Series Voltage Reference 3-SOT-23 -40℃ to 125℃ | |||
REF3140AIDBZTG4 Texas Instruments | 93 ₽ | ||
REF3140AIDBZTG4 Texas Instruments | 126 ₽ | ||
REF3140AIDBZTG4 | по запросу | ||
REF3140AIDBZTG4 Texas Instruments | по запросу |
Pin | 3 |
Package Type | DBZ |
Industry STD Term | SOT-23 |
JEDEC Code | R-PDSO-G |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | R31D |
Width (мм) | 1.3 |
Length (мм) | 2.92 |
Thickness (мм) | 1 |
Pitch (мм) | .96 |
Max Height (мм) | 1.22 |
Mechanical Data | Скачать |
Initial Accuracy(Max) | 0.2 % |
Iout/Iz(Max) | 10 мА |
Iq(Max) | 115 uA |
Iq(Typ) | 100 uA |
LFN 0.1-10Hz(Typ) | 53 ОјVpp |
Package Group | SOT-23 |
Package Size: mm2:W x L | 3SOT-23: 4 mm2: 1.3 x 2.92(SOT-23) PKG |
Pin/Package | 3SOT-23 |
Rating | Catalog |
Special Features | N/A |
Temp Coeff(Max) | 15,20 ppm/ degree C |
Temp Coeff(Typ) | 5,10 ppm/ degree C |
VO | 4.096 В |
Vin(Max) | 5.5 В |
Vin(Min) | 4.146 В |
- High-Voltage Signal Conditioning for Differential ADCsPDF, 125 Кб, Файл опубликован: 14 июн 2004
Analog designers are frequently required to convert high-voltage signals to levels acceptable to low-voltage data converters with differential inputs. This paper describes solutions for this common task using modern amplifiers and typical power supplies. Three examples of conditioning В±10V bipolar signals for low-voltage analog-to-digital converters (ADCs) are shown: a single-supply design,
Серия: REF3140 (4)
- REF3140AIDBZR REF3140AIDBZRG4 REF3140AIDBZT REF3140AIDBZTG4
- Semiconductors > Power Management > Voltage Reference > Series Voltage Reference
