Datasheet Texas Instruments SN74LVC1G19YZPR — Даташит
Серия | SN74LVC1G19 |
Модель | SN74LVC1G19YZPR |
![Datasheet Texas Instruments SN74LVC1G19YZPR](http://www.ti.com/graphics/folders/partimages/SN74LVC1G19.jpg)
Декодер/демультиплексор 1 из 2 6-DSBGA от -40 до 85
SN74LVC1G19 1-of-2 Decoder and Demultiplexer datasheet
PDF, 1.3 Мб, Версия: G, Файл опубликован: 31 авг 2015
![]() 19 предложений от 12 поставщиков IC: цифровая; от 2 до 4 линий,декодер,демультиплексор; Ch: 2 | |||
SN74LVC1G19YZPR Texas Instruments | 9.14 ₽ | ||
SN74LVC1G19YZPR Texas Instruments | 14 ₽ | ||
SN74LVC1G19YZPR Texas Instruments | от 81 ₽ | ||
SN74LVC1G19YZPR Texas Instruments | по запросу |
Pin | 6 | 6 |
Package Type | YZP | YZP |
Industry STD Term | DSBGA | DSBGA |
JEDEC Code | R-XBGA-N | R-XBGA-N |
Package QTY | 3000 | 3000 |
Carrier | LARGE T&R | LARGE T&R |
Маркировка | CYN | CY7 |
Width (мм) | .9 | .9 |
Length (мм) | 1.5 | 1.5 |
Thickness (мм) | 2 | 2 |
Pitch (мм) | .5 | .5 |
Max Height (мм) | .5 | .5 |
3-State Output | No |
Bits | 1 |
F @ Nom Voltage(Max) | 150 Mhz |
Gate Type | DECODER/DEMUX |
ICC @ Nom Voltage(Max) | 0.01 мА |
Logic | True |
Output Drive (IOL/IOH)(Max) | 32/-32 мА |
Package Group | DSBGA |
Package Size: mm2:W x L | See datasheet (DSBGA) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Special Features | Ioff,down translation to Vcc,low power |
Sub-Family | Decoder/Encoder/Multiplexer |
Technology Family | LVC |
VCC(Max) | 5.5 В |
VCC(Min) | 1.65 В |
Voltage(Nom) | 1.8,2.5,3.3,5 В |
tpd @ Nom Voltage(Max) | 16.1,6.5,5.2,3.9 нс |
- LVC Characterization InformationPDF, 114 Кб, Файл опубликован: 1 дек 1996
This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices. - Use of the CMOS Unbuffered Inverter in Oscillator CircuitsPDF, 796 Кб, Файл опубликован: 6 ноя 2003
CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC1G19 (11)
- Semiconductors > Logic > Little Logic
