Datasheet Texas Instruments TPA3005D2PHP — Даташит
СерияTPA3005D2
МодельTPA3005D2PHP
Стереоусилитель мощности звука класса D, 6 Вт (TPA3005) 48-HTQFP от -40 до 85
TPA3005D2: 6-W Stereo Class-D Audio Power Amplifier datasheet
PDF, 967 Кб, Версия: A, Файл опубликован: 19 авг 2010
TEXAS INSTRUMENTS TPA3005D2PHP Audio Power Amplifier, D, 2Channel, 6W, 8.5V to 18V, HTQFP, 48Pins
Akcel
TPA3005D2PHP
от 34 ₽
TPA3005D2PHP
85 ₽
Элитан
TPA3005D2PHP
90 ₽
ЗУМ-СМД
TPA3005D2PHP
Критерии выбора литиевых аккумуляторов и батареек: что необходимо учитывать разработчикам
Pin48
Package TypePHP
Industry STD TermHTQFP
JEDEC CodeS-PQFP-G
Package QTY250
CarrierJEDEC TRAY (5+1)
МаркировкаTPA3005D2
Width (мм)7
Length (мм)7
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
Analog Supply (V)18 Min
Audio Input TypeAnalog
Closed/Open LoopOpen
Control InterfaceHardware
Package GroupHTQFP
Package Size: mm2:W x L48HTQFP: 81 mm2: 9 x 9(HTQFP) PKG
Power Stage Supply(Max)18 В
Power Stage Supply(Min)8.5 В
Power to Bridge Tied Load(Max)6 W
Speaker Channels2 Max
Supported Bridge Tied Load(Min)8 Ohms
  • Evaluation Modules & Boards: TPA3005D2EVM
    TPA3005D2 Evaluation Module (EVM)
  • AN-1737 Managing EMI in Class D Audio Applications (Rev. A)
    PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
    Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit.
  • Using Thermal Calculation Tools for Analog Components
    PDF, 1.1 Мб, Файл опубликован: 2 сен 2010
    This document provides general guidance on the use of toolsand calculations for thermal estimates of component operating temperatures for analog devices. Of particularfocus are components with direct thermal paths to the PCB which is common for components which need a low thermal resistance to manage the dissipated power. This document provides practical considerations for estimation of o
  • AN-1849 An Audio Amplifier Power Supply Design (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
    This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs.
  • Guidelines for Measuring Audio Power Amplifier Performance
    PDF, 765 Кб, Файл опубликован: 30 окт 2001
    This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TPA3005D2 (4)
  • Semiconductors > Audio > Mid-Power Audio Amplifiers (10-50W) > Analog Input Amplifiers
На английском языке: Datasheet Texas Instruments TPA3005D2PHP
