Datasheet Texas Instruments SN74LVCR16245ADGVR — Даташит
Серия | SN74LVCR16245A |
Модель | SN74LVCR16245ADGVR |
16-БИТНЫЙ ШИННЫЙ ТРАНСИВЕР С 3-СОСТОЯННЫМИ ВЫХОДАМИ 48-TVSOP от -40 до 85
SN74LVCR16245A 16-Bit Bus Transceiver with 3-State Outputs datasheet
PDF, 954 Кб, Версия: B, Файл опубликован: 6 май 2014
Купить SN74LVCR16245ADGVR на РадиоЛоцман.Цены — от 97 до 277 ₽ 15 предложений от 9 поставщиков 16Bit BUS TRANSCEIVER WITH 3-STATE OUTPUTS 48-TVSOP -40℃ to 85℃ | |||
SN74LVCR16245ADGVR Texas Instruments | 97 ₽ | ||
SN74LVCR16245ADGVR Texas Instruments | от 110 ₽ | ||
SN74LVCR16245ADGVR Texas Instruments | 121 ₽ | ||
SN74LVCR16245ADGVR Texas Instruments | по запросу |
Pin | 48 |
Package Type | DGV |
Industry STD Term | TVSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | LDR245A |
Width (мм) | 4.4 |
Length (мм) | 9.7 |
Thickness (мм) | 1.05 |
Pitch (мм) | .4 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Bits | 16 |
F @ Nom Voltage(Max) | 100 Mhz |
ICC @ Nom Voltage(Max) | 0.02 мА |
Output Drive (IOL/IOH)(Max) | -12/12 мА |
Package Group | TVSOP |
Package Size: mm2:W x L | 48TVSOP: 62 mm2: 6.4 x 9.7(TVSOP) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | LVC |
VCC(Max) | 3.6 В |
VCC(Min) | 1.65 В |
Voltage(Nom) | 1.8,2.5,2.7,3.3 В |
tpd @ Nom Voltage(Max) | 7.8,5.8,5.7,4.8 нс |
Серия: SN74LVCR16245A (5)
- 74LVCR16245ADGGRG4 SN74LVCR16245ADGGR SN74LVCR16245ADGVR SN74LVCR16245ADLR SN74LVCR16245AZQLR
- Semiconductors > Logic > Buffer/Driver/Transceiver > Standard Transceiver
