Datasheet Texas Instruments 5962-9751601QCA — Даташит
СерияSN54S15
Модель5962-9751601QCA
Тройные логические элементы положительного И с 3 входами и выходами с открытым коллектором 14-CDIP от -55 до 125
Pin14
Package TypeJ
Industry STD TermCDIP
JEDEC CodeR-GDIP-T
Width (мм)6.67
Length (мм)19.56
Thickness (мм)4.57
Pitch (мм)2.54
Max Height (мм)5.08
RoHSНе совместим
  • Live Insertion
  • Shelf-Life Evaluation of Lead-Free Component Finishes
    PDF, 1.3 Мб, Файл опубликован: 24 май 2004
    The integrated circuit (IC) industry is converting to lead (Pb)-free termination finishes for leadframe-based packages. IC component users need to know the maximum length of time that components can be stored prior to being soldered. This study predicts shelf life of the primary Pb-free finishes being proposed by the industry. Components were exposed to a controlled environment, with known aging a
Серия: SN54S15 (5)
  • Semiconductors > Space & High Reliability > Logic Products > Gate Products
59629751601QCA, 5962 9751601QCA
На английском языке: Datasheet Texas Instruments 5962-9751601QCA
