Datasheet Texas Instruments OPA360AIDCKT — Даташит
Серия | OPA360 |
Модель | OPA360AIDCKT |
3 В, видеоусилитель с фильтром нижних частот, внутренним G=2 и коррекцией провисания в SC70 6-SC70 от -40 до 85
3V Video Amplifier with 6dB Gain and Filter in SC70 datasheet
PDF, 1.3 Мб, Версия: E, Файл опубликован: 8 сен 2006
Купить OPA360AIDCKT на РадиоЛоцман.Цены — от 13 до 440 ₽ 33 предложений от 18 поставщиков Усилитель видеосигнала, 1 усилитель(-ей), -40 °C, 85 °C, 80 мА | |||
OPA360AIDCKT Texas Instruments | от 13 ₽ | ||
OPA360AIDCKT Texas Instruments | 28 ₽ | ||
OPA360AIDCKT Texas Instruments | от 166 ₽ | ||
OPA360AIDCKT Texas Instruments | по запросу |
Pin | 6 |
Package Type | DCK |
Industry STD Term | SOT-SC70 |
JEDEC Code | R-PDSO-G |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | AUW |
Width (мм) | 1.25 |
Length (мм) | 2 |
Thickness (мм) | .9 |
Pitch (мм) | .65 |
Max Height (мм) | 1.1 |
Mechanical Data | Скачать |
Diff Gain | 0.5 % |
Diff Phase | 1 deg |
Количество каналов | 1 |
Output Current(Typ) | 80 мА |
Package Group | SC70 |
Package Size: mm2:W x L | 6SC70: 4 mm2: 2.1 x 2(SC70) PKG |
Rating | Catalog |
Vs(Max) | 3.6 В |
Vs(Min) | 2.5 В |
- Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA360 (4)
- OPA360AIDCKR OPA360AIDCKRG4 OPA360AIDCKT OPA360AIDCKTG4
- Semiconductors > Amplifiers > Special Function Amplifiers > Video Amplifiers
