Datasheet Texas Instruments BQ2002SNTR — Даташит
Серия | BQ2002 |
Модель | BQ2002SNTR |
Контроллер заряда NiCd/NiMH с выводом отрицательного dV и пикового напряжения 8-SOIC 0–70
NiCD/NiMH Fast-Charge Management ICs datasheet
PDF, 691 Кб, Версия: A, Файл опубликован: 20 апр 2009
Купить BQ2002SNTR на РадиоЛоцман.Цены — от 37 до 108 ₽ 15 предложений от 12 поставщиков Battery Charge Management NiCd/NiMH Charge Controller with Negative dV and Peak Voltage Detection Termination Fast Charge Management NiCD/NiMH 2000mA 8Pin SOIC... | |||
BQ2002SNTR Texas Instruments | от 37 ₽ | ||
BQ2002SNTR Texas Instruments | 71 ₽ | ||
BQ2002SNTR Texas Instruments | 108 ₽ | ||
BQ2002SNTR Texas Instruments | по запросу |
Pin | 8 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | 2002 |
Width (мм) | 3.91 |
Length (мм) | 4.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Absolute Vin (safety rating)(Max)( | 7 В |
Battery Charge Voltage(Max) | 20 В |
Cell Chemistry | NiCd,NiMH |
Charge Current(Max) | 2 A |
Control Interface | Standalone (RC-Settable) |
Control Topology | Linear |
Number of Series Cells | 1,2,3,4 |
Operating Vin(Max) | 6 В |
Operating Vin(Min) | 4 В |
Package Group | SOIC |
Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
Special Features | Temp Monitoring (Thermistor Pin) |
USB Feature | N/A |
- Evaluation Modules & Boards: DV2002L2
BQ2002 Evaluation Module for NiCd/NiMH, Linear with -dV or Peak Voltage Detect
- Using the bqSWITCHER, bq24115, as a Nickel ChargerPDF, 151 Кб, Файл опубликован: 5 янв 2007
This application report describes the combination of the bqSWITCHERв„ў bq24115 charge management device and the bq2002 battery charge controller to provide a high-efficiency-switching charging solution for nickel battery packs. - Battery Charger Termination Issues With System Load Applied Across Battery (Rev. A)PDF, 151 Кб, Версия: A, Файл опубликован: 2 окт 2006
Battery Charger Termination Issues With System Load Applied Across Battery While Charging
Серия: BQ2002 (6)
- BQ2002PN BQ2002PNE4 BQ2002SN BQ2002SNG4 BQ2002SNTR BQ2002SNTRG4
- Semiconductors > Power Management > Battery Management Products > Battery Charger IC
