Двойные триггеры JK с отрицательным фронтом, с прозрачными и предустановленными 16-SOIC от -40 до 85
PDF, 1.3 Мб, Файл опубликован: 24 май 2004
The integrated circuit (IC) industry is converting to lead (Pb)-free termination finishes for leadframe-based packages. IC component users need to know the maximum length of time that components can be stored prior to being soldered. This study predicts shelf life of the primary Pb-free finishes being proposed by the industry. Components were exposed to a controlled environment, with known aging a
