Datasheet Texas Instruments 74AUC1G240DBVRG4 — Даташит
Серия | SN74AUC1G240 |
Модель | 74AUC1G240DBVRG4 |
Одиночный буфер/драйвер с выходом с 3 состояниями 5-SOT-23 от -40 до 85
Single Buffer/Driver With 3-State Output datasheet
PDF, 974 Кб, Версия: I, Файл опубликован: 5 фев 2007
Купить 74AUC1G240DBVRG4 на РадиоЛоцман.Цены — от 8.58 до 14 ₽ 8 предложений от 8 поставщиков Buffer, Inverting 1 Element 1 Bit per Element 3-State Output SOT-23-5 | |||
74AUC1G240DBVRG4 Texas Instruments | 8.58 ₽ | ||
74AUC1G240DBVRG4 Texas Instruments | 10 ₽ | ||
74AUC1G240DBVRG4 Texas Instruments | 14 ₽ | ||
74AUC1G240DBVRG4 Texas Instruments | по запросу |
Pin | 5 |
Package Type | DBV |
Industry STD Term | SOT-23 |
JEDEC Code | R-PDSO-G |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | U40R |
Width (мм) | 1.6 |
Length (мм) | 2.9 |
Thickness (мм) | 1.2 |
Pitch (мм) | .95 |
Max Height (мм) | 1.45 |
Mechanical Data | Скачать |
3-State Output | Yes |
Bits | 1 |
F @ Nom Voltage(Max) | 250 Mhz |
Gate Type | BUFFER |
ICC @ Nom Voltage(Max) | 0.01 мА |
Logic | Inverting |
Output Drive (IOL/IOH)(Max) | 9/-9 мА |
Package Group | SOT-23 |
Package Size: mm2:W x L | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Special Features | IOFF,low power consumption,low tpd |
Sub-Family | Non-Inverting Buffer/Driver |
Technology Family | AUC |
VCC(Max) | 2.7 В |
VCC(Min) | 0.8 В |
Voltage(Nom) | 0.8,1.2,1.5,1.8,2.5 В |
tpd @ Nom Voltage(Max) | 4.5,3.3,2.2,1.7,1.4 нс |
- Application of the Texas Instruments AUC Sub-1-V Little Logic Devices (Rev. A)PDF, 449 Кб, Версия: A, Файл опубликован: 19 сен 2002
Power consumption and speed are always concerns in electronic system logic design. Texas Instruments (TI) announces the industry?s first sub-1-V logic family that provides significant benefits to portable consumer electronics by operating at low power and high speed, while maintaining overall system signal integrity. TI?s next-generation logic family is the advanced ultra-low-voltage CMOS (AUC) fa - Designing With TI Ultra-Low-Voltage CMOS (AUC) Octals and Widebus DevicesPDF, 374 Кб, Файл опубликован: 21 мар 2003
System designers are continuously seeking ways to improve signal integrity, increase speed, and reduce power consumption in personal computers, telecommunication equipment, and other electronic systems. The Texas Instruments (TI) next-generation Advanced Ultra-low-voltage CMOS (AUC) octals and Widebus(TM) devices are designed to achieve these goals. These devices are designed for a 0.8-V to 2.7-V - How to Select Little Logic (Rev. A)PDF, 1.1 Мб, Версия: A, Файл опубликован: 26 июл 2016
TI Little Logic devices are logic-gate devices assembled in a small single- dual- or triple- gate package. Little Logic devices are widely used in portable equipment such as mobile phones MP3 players and notebook computers. Little Logic devices also are used in desktop computers and telecommunications. Little Logic gates are common components for easy PC board routing schematic design and b - Texas Instruments Little Logic Application ReportPDF, 359 Кб, Файл опубликован: 1 ноя 2002
Portable and consumer electronic systems? needs present greater challenges today than ever before. Engineers strive to design smaller faster lower-cost systems to meet the market demand. Consequently the semiconductor industry faces a growing need to increase operating speed minimize power consumption and reduce packaging size. Texas Instruments manufactures a variety of Little Logic semicond - Selecting the Right Level Translation Solution (Rev. A)PDF, 313 Кб, Версия: A, Файл опубликован: 22 июн 2004
Серия: SN74AUC1G240 (4)
- 74AUC1G240DBVRG4 SN74AUC1G240DBVR SN74AUC1G240DCKR SN74AUC1G240YZPR
- Semiconductors > Logic > Little Logic
